电子发烧友论坛|
任何人都可以提供以下帮助:我们仍在使用HP 8673D信号发生器,并且使用HP 11726-1000A盒式磁带和HP 85D控制器已经多年来校准/调整它们。
几个月前我们的HP 85D控制器出了问题,我们无法获得任何备件(不足为奇)。 安捷伦(或任何其他人)是否已将HP 11726-1000A盒式磁带上的HP 8673D调整程序转换为任何其他介质,因为我们无法再读取盒式磁带以在HP(HT)Basic中运行它......如果没有,是否有人有手册 调整这些发电机的程序? 以上来自于谷歌翻译 以下为原文 Can anyone help with the following: We still are using the HP 8673D signal generators and have been calibrating / adjusting them for years now using the HP 11726-1000A Cassette and HP 85D controller. Our HP 85D controller went wrong several months ago and we are unable to get any spares (not surprisingly). Did Agilent (or anyone else) convert the HP 8673D adjustment program on the HP 11726-1000A Cassette to any other media since we can no longer read the cassette to run it in HP (HT) Basic…… If not does anyone have a manual procedure for the adjustment of these generators? |
5个回答
您好 - 不太可能将旧的调整软件迁移到任何其他格式。
我们检查了罗斯维尔服务中心。 在尽力而为的基础上,他们仍然可以进行性能测试,修复和8673D的调整。 73D上的大多数调整都是手动的,但是一些处理功率级准确度的测试是自动化的。我们在这个旧产品上提供的最好的是服务中心可能能够修复和提供调整。 并且,如果只需要,则提供性能验证。 在任何这些情况下,您都应首先请求Tech Eval确定服务中心是否支持在此设备上需要执行的操作。相关产品:#8673D# 以上来自于谷歌翻译 以下为原文 Hello - It is very unlikely any effort was put in to migrating old adjustment software into any other format. We checked with the Roseville Service Center. On a best effort basis they can still do Performance Tests, Repair and do Adjustments of the 8673D’s. Most of the adjustments on the 73D are manual though some tests dealing with Power Level Accuracy are automated. The best we can offer on this old product is the possibility that the Service Center might be able to Repair and provide Adjustments. And, provide Performance Verification if that is all that is needed. In any of these cases, you should request a Tech Eval first to determine if what needs to be done on this unit can be supported by the Service Center. Regards - Relevant Products:#8673D# |
HelloJust与那些正在对这些单位进行调整的人进行了聊天,他们刚从美国空军收到了8673D,AFPSL通过罗斯维尔,这花了10个多月,主要是因为我们目前驻扎在中间
东。 他们一直在做的只是由于交付时间而发送需要维修的设备,因为他们无法再调整他们最终将8673D送回美国进行微调而不是修理的设备的功率水平。 这些家伙说他们已经尝试手动调整功率水平,因为HP85失效,虽然取得了一些小小的成功,但是使用旧软件的速度更快,更成功。是否有11726-10004的程序列表(整体或只是 存在水平部分)以便我可以花时间将其转换为在HP / HT Basic中运行,这样就不会影响这些旧发电机的停机时间。 以上来自于谷歌翻译 以下为原文 Hello Just had a chat with the guys who were carrying out the adjustment on these units, they have just received a 8673D back from the USAF, AFPSL via Roseville, it took over 10 months, due mainly to the fact we are currently stationed in the Middle East. What they have been doing is only sending out the units that required repair due to the lead time, as they can no longer adjust the power level on the units they end up sending the 8673D’s back to the US for minor adjustments and not repair. The guys said they have tried manually adjusting the power level since the HP85 went out of commission, with some small success, but were far quicker and more successful using the old software. Does a program listing for the 11726-10004 (in whole or just the leveling part) exist so that I could spend time converting it to run in HP/HT Basic so this does not effect the down time on these old generators. Regards |
由于我们无法读取原始磁带,因此我们无法对其进行转换。
如果有人有原始程序可以保存为文本文件并发送给我们,我们可以看看转换它。 一些旧的HP基本程序使用CSUB,其中“旧”协处理器“照顾”,这将导致HT基本转换过程中出现问题....去年我们有一个升级,所以大部分的8673Ds 现在不再使用了,所以它将不再是一个高优先级。 问候 以上来自于谷歌翻译 以下为原文 Since we cannot read the original tape, we cannot convert it. If anyone has the original program that can be saved as a text file and sent to us, we can look at converting it. Some of the old HP basic programs use CSUBs which where 'taken care' of by the 'old' Co-processors, this will cause problems during the HT Basic conversion.... We had an up grade last year so most of the 8673Ds are now no longer used here, so it will no longer be a high priority. Regards |
60user72 发表于 2019-7-26 08:10 你好, 我最近遇到过这个帖子并且有兴趣获取任何8673的调整带或一组磁带(11726A)上的关键数据。请尽快通过我的个人资料通过电子邮件与我联系,讨论两者的可能解决方案。 85电脑和录像带。 原始HP 85磁带最终会随着时间的推移而降级,无论在什么条件下(在极端条件下更快),我担心这些30年前的磁带数据将永远丢失或损坏。 HP 85的磁带机本身将有一个橡胶轮,现在通常会变成糊状物质。 如果其他人遇到此主题,欢迎您与我联系。 此致 莱克斯 以上来自于谷歌翻译 以下为原文 Hello, I have recently come across this thread and have an interest in obtaining the crucial data on the adjustment tape or set of tapes (11726A) for any 8673. As soon as possible please contact me by email through my profile to discuss possible solutions for both the 85 computer and the tape. An original HP 85 tape will eventually degrade over time no matter what condition (sooner in extreme conditions) and I'm afraid the data will be forever lost or corrupted for these 30 year old tapes. The HP 85's tape drive itself will have a rubber wheel that usually by now turns into a paste-like substance. If anyone else here comes across this thread you're welcome to contact me as well. Sincerely, Lex |
只有小组成员才能发言,加入小组>>
1855 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3476 浏览 3 评论
1857浏览 0评论
429浏览 0评论
59浏览 0评论
/9
GMT+8, 2025-12-10 00:09 , Processed in 1.120770 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1605
