电子发烧友论坛|
嗨,
我可以买一台新的PC进行开发。 使用两个工具链,ISE(V6)和VIVADO(ZYNQ)。 我的问题是,哪个系统会更快(只有性能,而不是价格): i7-7700K + 4.2-4.5 GHz - 4个核心(8个线程) - 8 MB缓存 - 2通道RAM DDR4-2400(2x 16 GB) 要么 i7-6850K -3.6-3.8 GHz + 6个核心(12个线程) +15 MB缓存 + 4通道RAM DDR4-2400(4x 8 GB) 有谁有线索,更重要的是什么? CPU频率核心+缓存+ RAM? 或者是否有人对更快的系统(没有超频)有任何其他建议? (PS:应使用Linux) thx in avance DM 以上来自于谷歌翻译 以下为原文 Hi, i'm able to get a new PC for development. Both toolchains, ISE (V6) und VIVADO (ZYNQ) are used. My question is, which System would be the faster one (only performance, not price): i7-7700K + 4.2-4.5 GHz - 4 Cores (8 Threads) - 8 MB Cache - 2 Channel RAM DDR4-2400 (2x 16 GB) or i7-6850K -3.6-3.8 GHz + 6 Cores (12 Threads) +15 MB Cache + 4 Channel RAM DDR4-2400 (4x 8 GB) Does anyone have a clue, what more important is? CPU Frequency <-> Cores + Cache + RAM? Or does anyone have any other suggestion for an even faster system (no overclocking)? (PS: Linux shall be used) thx in avance dm |
1个回答
在将i7-5775C与英特尔最近的处理器进行基准测试时,我得到了很好的结果。
它已经两代了,它没有特别高的时钟速度,它不支持很多线程。 但它有一个128MB的L4缓存,这是最新的可插拔CPU所没有的。 (嵌入式DRAM旨在加速集成显卡,但如果使用外置(PCI-e)显卡,它似乎可用作L4缓存。) 在我的基准测试中,Vivado的速度并没有随着可用内核的数量而明显改变。 ISE PAR有一个选项,允许您指定它可以使用的线程数。 我的经验是,1,2,3或4个线程之间至多有几个百分点的差异。 有时4慢于1。 请记住,您的Vivado跑步将由不同的通行证组成。 一些(例如IP集成)将大量访问磁盘。 一些(例如路由)将受CPU或内存限制。 问候, 艾伦 以上来自于谷歌翻译 以下为原文 I get good results when benchmarking an i7-5775C against more recent processors from Intel. It's two generations old, it doesn't have a particularly high clock speed, it doesn't support many threads. But it has a 128MB L4 cache that the more recent pluggable CPUs don't have. (The embedded DRAM is meant to speed up the integrated graphics, but it seems that it's available as L4 cache if you use an external (PCI-e) graphics card.) In my benchmarks, the speed of Vivado does not change appreciably with the number of cores available. ISE PAR has an option that allows you to specify the number of threads it can use. My experience is that there is at most a few % difference between 1, 2, 3, or 4 threads. Sometimes 4 is slower than 1. Please bear in mind that your Vivado run will be made up of different passes. Some (e.g. IP integration) will access the disk a lot. Some (e.g. routing) will be CPU or memory bound. Regards, Allan |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1197浏览 1评论
/9
GMT+8, 2025-12-13 23:32 , Processed in 0.691700 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
15778
