你好,
我是ZYBO Zynq 7000开发板的新手,通常也是FPGA的世界。 1)我即将安装我的开发程序(ISE / Vivado)。 如何区分它们以便为我的工作选择合适的一个。 考虑到我已经尝试了这两种方法,并且我对Vivado有着非凡的兴趣,但是从随机的简单项目经验(控制LED,简单的数字电路)。 2)在安装方面,如何选择版本? 考虑到我正在寻找能够访问所有设计和开发功能的版本。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am new to my ZYBO Zynq 7000 Development Board and, generally, the world of FPGAs. 1) I am about to install my development program (ISE/Vivado). How to differentiate between both of them in order to choose the suitable one for my work. Considering that I already tried both of them and I have a remarkable tendancy to Vivado, but from random experience of working on simple projects (controlling LEDs, simple digital circuits). 2) When it comes to the installation, how to choose the edition? Considering that I am seeking the edition that gives me access to all design and development features. Thanks! |
4个回答
@asobeih,
检查类似的论坛帖子: https://forums.xilinx.com/t5/Design-Entry/What-is-the-main-difference-between-Vivado-and-ISE/td-p/270000 还要查看不同版本的Vivado: http://www.xilinx.com/products/design-tools/vivado.html#buy 对于ISE: http://www.xilinx.com/products/design-tools/ise-design-suite.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @asobeih, Check the similar forum thread: https://forums.xilinx.com/t5/Design-Entry/What-is-the-main-difference-between-Vivado-and-ISE/td-p/270000 Also check the different edition of Vivado: http://www.xilinx.com/products/design-tools/vivado.html#buy For ISE: http://www.xilinx.com/products/design-tools/ise-design-suite.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
HI @ asobeih,
你的意思是webpack,系统版本,设计等吗? 如果是这样,这取决于您的要求。 请浏览以下链接的第29页: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug973-vivado-release-notes-install-license.pdf 谢谢,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 HI @asobeih, Do you mean webpack,system edition, design edition and so? If so this depends on your requirement. Please go through page-29 of following link: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug973-vivado-release-notes-install-license.pdf Thanks, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@ asobeih,
1.选择Vivado会更好,因为它是我们当前的工具,我们每年至少有4次更新,而ISE正在维护中。 Vivado提供了一些ISE.Plus中没有的功能,您之前已经在Vivado上工作过,因此您可以更轻松地使用它。 始终选择最新版本,目前是Vivado 2016.1。 您可以从此处下载:http://www.xilinx.com/support/download.html 2. Vivado系统版将为您提供所有功能。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @asobeih, 1. Choosing Vivado will be better as it is our current tool, and we have atleast 4 updates to it every year, while ISE is under maintenance. Vivado provides some features which were not there in ISE. Plus you have worked on Vivado earlier, so it will be easier for you to use. Always opt for the latest version, which currently is Vivado 2016.1. You can download it from here: http://www.xilinx.com/support/download.html 2. Vivado system Edition will provide you with all features. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
一个,
Vivado。 ISE 14.7是ISE的最后一个版本,不会更新/改进。 它适用于28nm(7系列)之前的所有产品。 Vivado是与过去的彻底决裂,是唯一向前发展的工具。 这里没有灰色阴影:它是黑色和白色 - 7系列或更新的任何产品都使用Vivado。 我确实知道Zynb的一些示例设计是在ISE上完成的,但是我不建议你使用它们,因为它们现在已经很老了,并且Vivado存在更好的例子。 一个注意事项:对于参考设计,请加载并使用指定的版本以获得最佳结果。 如果示例设计在2014.3中,那么这就是要使用的版本。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 a, Vivado. ISE 14.7 is last (ever) version of ISE, and will not be updated/improved. It is for all products before 28nm (7 series). Vivado is the clean break with the past, and is the only tool moving forward. No shades of gray here: it is black and white -- any product in 7 series, or newer, use Vivado. I do realize some example designs for Zynb are out there done on ISE, but I do not recommend you use them as they are now quite old, and better examples exist for Vivado. One caution: for a reference design, load and use the version specified for best results. If the example design is in 2014.3, then that is the version to use. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2416 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3372 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2459 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1142浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
581浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
447浏览 1评论
2002浏览 0评论
726浏览 0评论
GMT+8, 2024-12-22 13:57 , Processed in 1.387231 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
