电子发烧友论坛|
你好。
我正在尝试在STM8S105(发现板)上的timer2(通道3)上使用输入捕捉模式。它不起作用,当我用适当的断点观察外围寄存器时,寄存器不会从默认值改变。 我使用STVD和cosmic编译器。我正在使用固件库。 (我已经检查过,每个宏都指向正确的寄存器。) 这是我的代码中的所有相关内容: CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER2,ENABLE); GPIO_Init(GPIOD,GPIO_PIN_2,GPIO_MODE_IN_PU_NO_IT); //! modify option bytes:为AFR1选择TIMR2-CH3 TM2_DISABLE; //宏复位TMR2-> CR1寄存器中的CEN位 TIM2_DeInit(); TIM2_TimeBaseInit(TIM2_PRESCALER_1,0xFEFE); //从FFFF更改为FEFE以查看它是否对ARR寄存器应用任何更改,并且它不会:/ TIM2_ICInit(TIM2_CHANNEL_3, TIM2_ICPOLARITY_FALLING, TIM2_ICSELECTION_DIRECTTI, TIM2_ICPSC_DIV1, 0); TIM2_ITConfig(TIM2_IT_CC3,ENABLE); TIM2_CCxCmd(TIM2_CHANNEL_3,ENABLE); TM2_ENABLE; //宏设置TMR2-> CR1寄存器中的CEN位 有没有人在聊天的线索我忘了启用所以这个外围设备可能有用吗? 以上来自于谷歌翻译 以下为原文 Hi. I'm trying to use Input Capture mode on Timer2 (channel 3) on an STM8S105 (discovery board). It won't work, and when i m watching peripheral registers with appropriated breakpoints, the registers aren't changing from default value. I m using STVD with cosmic compiler. I'm using firmware libraries. (i already checked out, that every macros was pointing to the right register.) Here's everything relevant in my code : CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER2, ENABLE); GPIO_Init(GPIOD, GPIO_PIN_2, GPIO_MODE_IN_PU_NO_IT); //! modify option bytes : select TIMR2-CH3 for AFR1 TM2_DISABLE; //macro resetting CEN bit in TMR2->CR1 register TIM2_DeInit(); TIM2_TimeBaseInit(TIM2_PRESCALER_1, 0xFEFE); // changed from FFFF to FEFE to see if it applies any change to ARR register, and it does not :/ TIM2_ICInit(TIM2_CHANNEL_3, TIM2_ICPOLARITY_FALLING, TIM2_ICSELECTION_DIRECTTI, TIM2_ICPSC_DIV1, 0); TIM2_ITConfig(TIM2_IT_CC3, ENABLE); TIM2_CCxCmd(TIM2_CHANNEL_3, ENABLE); TM2_ENABLE; //macro setting CEN bit in TMR2->CR1 register Has anyone a clue on chat i forgot to enable so this peripheral might work ? |
2个回答
这里有一个更精确的例子:
TIM2-> CR1 | =(uint8_t)TIM2_CR1_CEN; 在此指令之后,我将看到TIM2-CR1(地址0x5300)的寄存器从0x00变为0x01。 但它不会工作......我已经检查了base_address,宏,参考手册和外设寄存器,它们都指向相同的地址0x5300。 我的时钟也启用了。我使用HSI作为主时钟。 以上来自于谷歌翻译 以下为原文 here a more precise example : TIM2->CR1 |= (uint8_t)TIM2_CR1_CEN; after this instruction i shall see register of TIM2-CR1 (address 0x5300) change from 0x00 to 0x01. But it won't work... and i already checked base_address, macros, ref manual, and peripheral registers, they re all pointing to the same address 0x5300. My clock is also enable. I'm using HSI as main clock. |
我终于找到了,我的错误:/
我正在启用/禁用每个外设时钟,但我保留了timer5和6,而它们不在STM8S105上,而timer5和2共享相同的地址。因此禁用timer5会禁用我的时钟.... 愚蠢的错误...... 以上来自于谷歌翻译 以下为原文 I finally found it, my mistake :/ i was enabling/disabling every peripheral clock, but i had kept timer5 and 6 whereas they re not on STM8S105, and timer5 and 2 share same adress. So disabling timer5 was disabling my clock.... Dumb mistake ... |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 20:21 , Processed in 1.249983 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1759
