电子发烧友论坛|
我有一个带有版本的E2969A PCIe PTC卡。
1.1.0.16 Windows测试安捷伦站点的PCIe 1.1一致性测试。 但是,文献中的一些链接引用和大多数网站似乎都被打破了。 我正在尝试在Windows 7 x64下以XP兼容模式安装所有软件,并且在将USB电缆远程连接到卡时,除了E2969A驱动程序外似乎安装正常。 如果我尝试在附加卡测试模式下手动安装E2969A XP驱动程序,我应该在哪里搜索它们,因为在Windows 7硬件检测时默认的驱动程序E2969A软件和测试套件安装失败(可能它会查找某些Windows 7驱动程序)。 是否有其他软件或测试套件我需要了解英特尔或其他如PDK或BIOS测试软件? 以上来自于谷歌翻译 以下为原文 I have an E2969A PCIe PTC card with ver. 1.1.0.16 Windows tests for the PCIe 1.1 compliance tests from the Agilent site. However, some of the link references from the literature and most of the web sites seem to be broken. I am trying to install all software in XP compatibility mode under Windows 7 x64 and its seems to install ok except the E2969A drivers when connecting remotely the USB cable to the card. If I try to manually install the E2969A XP drivers in Add-In Card Test Mode, where should I search for them, since the default driver installation fails at the Windows 7 hardware detection (probably it looks for some Windows 7 drivers). Are there any other software or test suites that I need to be aware from Intel or others such as PDK or BIOS test software? |
2个回答
Win7不支持E2969A,无论是64位还是32位版本。
没有其他SW或测试套件您需要使用PTC,IIRC。 我看了之后已经有一段时间了。 你还在寻找其他什么信息? E2969A在2007年被E2969B取代.'B'版本支持Gen2,以及其他测试。 人 以上来自于谷歌翻译 以下为原文 The E2969A is not supported under Win7, either the 64 or 32 bit version. There are no other SW or test suites that you should need to use the PTC, IIRC. It's been a while since I've looked at it. What other information were you looking for? The E2969A was replaced by the E2969B in 2007. The 'B' version supports Gen2, as well as additional tests. Al |
nvywyerwer 发表于 2019-4-15 19:27 Windows 7不受支持不是问题,我有一个XP许可证可用; 我刚刚意识到驱动程序正在1.1.0.16软件安装过程中的一个临时文件夹中打开(可以在Windows 7下以XP模式运行)并在USB连接到PTC卡后从那里安装 。 Gen 2 PTC对我来说太昂贵了,PCI-SIG表示仍然使用Gen 1 PTC。 在询问其他软件时,我指的是以下提及和链接:http://www.pcisig.com/specifications/pciexpress/compliance/compliance_library http://www.pcisig.com/specifications/pciexpress/compliance/compliance_library# bios展示了更多协议层特定的测试套件,以及英特尔产品开发套件的推荐,可能是安捷伦文献中特定的芯片组。 以上来自于谷歌翻译 以下为原文 Windows 7 not being supported is not a problem, I have one XP license available; I have just realized that the drivers are being unwrapped in a temporary folder mid-way in the 1.1.0.16 software installation process (which could dummy run itself under Windows 7 in XP mode) and installed from there after the USB connectivity to the PTC card. Gen 2 PTC is too expensive for me and PCI-SIG says that Gen 1 PTC is still being used. When asking about other software I was referring to the following mentions and links: http://www.pcisig.com/specifications/pciexpress/compliance/compliance_library http://www.pcisig.com/specifications/pciexpress/compliance/compliance_library#bios which show more protocol layer specific test suites, as well as the referrals to Intel's Product Development Kit, probably chipset specific, from the Agilent literature. |
只有小组成员才能发言,加入小组>>
1855 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3476 浏览 3 评论
1857浏览 0评论
429浏览 0评论
84浏览 0评论
/9
GMT+8, 2025-12-10 04:21 , Processed in 0.779604 second(s), Total 41, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
832
