技术参考手册:
HTTP://www. CyPress?COM/?DOCID=15539 第149页: 7:0数据[7:0] 到底是什么意思?我输入PRTXDR=0xFF(一直是x从0到4),并且我没有读取任何端口上的高电平。我在干什么?Ito是否有特殊的命令来支持PIN的价值? 将值写入端口或从端口读取值。 读取返回引脚的状态,而不是返回的值。 PRTXDR寄存器。 以上来自于百度翻译 以下为原文 In the Technical reference manual: http://www.cypress.com/?docID=15539 in page 149 states: 7:0 Data[7:0] What means that exactly? I input PRTXDR |=0xFF (been X from 0 to 4) and I didn't read a high level at any port writed. What I doing wong? have I to put a special command to stand the value in the pin? Write value to port or read value from port. Reads return the state of the pin, not the value in the PRTxDR register. |
4个回答
你必须将GPIO引脚设置为STDCPU和驱动模式,而不是Hyz和HiZZ模拟。通常,推荐的驱动模式很强。看看我博客下面的文章。这些文章提供了关于GPIOs的基本信息。
PSOC GPIO解谜-第1部分 PSoC GPIO去神秘化-第2部分 最好的问候, 加内什 以上来自于百度翻译 以下为原文 You have to set the GPIO pins to StdCPU and drive mode to anything other than HighZ and HighZ Analog. Usually, the recommended drive mode is Strong. Check out the below articles in my blog. These articles provide basic information about GPIOs. PSoC GPIO Demystified - Part1 PSoC GPIO Demystified - Part 2 Best Regards, Ganesh |
我只是这么做了,效果不错。谢谢你提供的信息。
以上来自于百度翻译 以下为原文 I just did that and It works. Thanks for the info. |
除此之外,有多少电流通过PRTXDR寄存器来提供手动处理的数字输出。我的数据表告诉模拟列缓冲器提供30Ma:
“ 高电流输出驱动器(两个具有30毫安驱动器的PSoC) 核心资源 软件处理的输出如何? 以上来自于百度翻译 以下为原文 Apart that, how many current provide a digital output handled manually by means PRTXDR register. My datasheet tells the analog column buffers provided 30mA: "" High current output drivers (two with 30 mA drive as a PSoC Core Resource) What about the outputs handled by software? |
模拟输出缓冲器具有30Ma的驱动能力。但是这些引脚仅限于模拟输出缓冲器连接的模拟输出引脚。当模拟输出不启用时,所有GPIO引脚能够采购15mA和下沉25mA的电流。
以上来自于百度翻译 以下为原文 The Analog output buffers have the 30mA drive capability. But these pins are limited to the Analog output pins that are connected to the analog output buffers. When analog output is not enabled, all GPIO pins are capable of sourcing 15mA and sinking 25mA of current. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2100 浏览 1 评论
1846 浏览 1 评论
3664 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1782 浏览 6 评论
1532 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
556浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
410浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
433浏览 2评论
379浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
905浏览 2评论
GMT+8, 2024-12-19 02:11 , Processed in 0.877088 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
