你好,
我正在尝试首次编程一个新的PSoC5模块。布局是从其他工作项目中复制的,但我仍然无法对设备进行编程。 在PSoC编程器中,设备显示在JTAG链(0E13C069)中,但校验和不能被读取,也不能正确执行任何其他读取操作。 在PSoC创建者中显示以下错误: dg.M033:选定的调试目标“CY8C5688 AXI-060未分配”与项目选定的设备“CY8C5688 AXI-060 ES1”不兼容。 (CyPress演示板的编程工作完美无瑕,尽管它完全一样。) 我如何解决这个问题? 我不认为它是www. CyPress。ID = 4和;RID=31908,因为复制的布局… 以上来自于百度翻译 以下为原文 Hello, I'm triing to programm a new PSOC5 module for the first time. The Layout is copied from an other working project but still I can't programm the device. In PSOC Programmer the device is shown in the JTAG chain (0E13C069), but the checksum can't be read nor any other reading operation is performed correctly. In PSOC Creator following error is displayed: dbg.M0033: The selected debug target 'CY8C5588AXI-060 UNASSIGNED' is not compatible with the project's selected device 'CY8C5588AXI-060 ES1'. (Programming of the cypress demo board works flawless, although it's exactly the same device.) How can I resolve this problem? I don't think it's www.cypress.com/?id=4&rID=31908 because of the copied layout... |
7个回答
你好,
这是因为有得到错误信息,你在PSoC Creator文档看。 “在这个窗口中选择目标设备没有硅ID和修改符合当前项目的选择装置。或者选择一个不同的调试目标在这里,或者去改变项目的选择装置。如果你相信目标检测版本号不正确,请确认选择的调试时钟是1/3芯片的总线时钟和试运行端口获得重置设备。” 选择正确的设备, 右键单击工作区中的& gt项目;设备选择>;选择合适的设备 你用的是cy8ckit-001或cy8ckit-0050?这是你使用的编程模式,jtagor SWD? 当做, DASG 以上来自于百度翻译 以下为原文 Hi cidex, This is the reason sighted for getting the error message which you are seeing in PSoC Creator documentation. "The target device selected in this window does not have a Silicon ID and Revision that matches the current project's selected device. Either pick a different debug target here, or go back and change the project's selected device. If you believe the target's detected revision number is incorrect, verify that the selected Debug Clock is 1/3 of the chip's Bus Clock and try running Port Acquire to reset the device." To select the correct device, Right click on the project in the workspace > Device Selector > Select the right device Are you using CY8CKIT-001 or CY8CKIT-0050? And which programming mode are you using, JTAG or SWD? Regards, dasg |
哈罗达斯,
我有同样的问题,PSoC 5不能被检测到。它显示了与上述相同的警告。 我尝试遵循您的指令,也出现在PSoC创建者屏幕上。 但没有效果。因此,我通过调试选择器重新选择PSoC5,并尝试改变频率。 调试时钟到1/3时钟的总线时钟和其他频率。 CIDEX的问题怎么办?你能帮助他吗? 请你帮帮我。 最好的问候, PABRO345 以上来自于百度翻译 以下为原文 Hallo dasg, i have the same problem that the PSOC 5 can't be detected. It shows the same warning as above described. I tried to follow your instructions which also appeared in the PSOC Creator screen. But it didn't work. So i reselected the PSoc5 via the the debug selector and also tried to change the frequency of the debug clock to 1/3 o f the bus clock and other frequencies. What happened with the problem of cidex. Were you able to help him? Can u please help me. Best regards, Pablo345 |
你好,
请读这个… HTTP://www. CyPress?COM/?ID=4和;RID=38529 来源:柏树 - Makarand Krishna Patil 以上来自于百度翻译 以下为原文 Hi, please read this .. http://www.cypress.com/?id=4&rID=38529 Source: Cypress -Makarand Krishna Patil |
我的创作今天开始这样做。我终于发现VDDIO1已经失去了与VDDD的连接。希望这有帮助。我还发现,微型电源引脚的电源也应该来自这个引脚。硅的标识现在是岩石固体。
以上来自于百度翻译 以下为原文 My creation started to do this today. I finally found that the VDDDio1 had lost the connection to VDDD. hope this helps. I also found that the supply power to the miniprog pin should come from this pin as well. The id of the silicon is now rock solid. |
问题解决了吗?我正面临这个问题。”错误:BG.M033:选定的调试目标“CY8C588LTI-LP097”与项目所选设备“CY8C5868 AXI-LP035”不兼容。
解决方案是什么 以上来自于百度翻译 以下为原文 Is the problem solved ? I am facing this issue. "Error: dbg.M0033: The selected debug target 'CY8C5888LTI-LP097' is not compatible with the project's selected device 'CY8C5868AXI-LP035'." What was the solution |
解决方案是什么?
创建者-GT;项目& Device Selector;并选择CY8C588LTI LP097。可能需要进行一些调整,检查消息。 鲍勃 以上来自于百度翻译 以下为原文 What was the solution? Creator -> Project -> Device Selector and there choose the CY8C5888LTI-LP097. Some adjustments might be needed, check for messages. Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 05:35 , Processed in 0.906123 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2578
