电子发烧友论坛|
你好,
在STM8S003F3U上根据数据表有1024(总ram) - 513(堆栈)= 510字节用于用户应用:零页面中256字节和Ram部分中的(510-256)= 254。 如果使用短堆栈编译选项,所有数据都会在零页面空间中自动加载,如果我使用超过256个字节,则会出错。 如果我使用长堆栈编译数据自动映射在上部页面:Ram页面,如果使用超过254,我有一个错误(正常,因为有结束堆栈重叠) 我没找到任何stm8的cosmic编译器用户指南。如果我尝试使用pragma强制链接器在不同的空间中设置数据,则错误是:pragma错位... 怎么可能使用混合数据映射零页面和ram页面? 非常感谢 regars 约翰 以上来自于谷歌翻译 以下为原文 Hello, on STM8S003F3U according to datasheet there is 1024(total ram) - 513(stack) = 510 bytes for user application: 256 byte in the zero page and (510-256)= 254 in Ram section. If use the short stack compilation option all data are automaticaly maped in the zero page space and i have an error if i use more than 256 bytes. if i use the long stack compilation data are mapped automaticaly in the upper page: the Ram page and i have an error if use more than 254 (normal because there is the end stack overlap) I did'nt find any cosmic compiler user guide for stm8. If i try to use pragma to force linker to set data in different space the error is : pragma misplaced ... How is it possible to use mixed data mapping zero page and ram page ??? thank's a lot regars johan |
1个回答
你好,
用户手册与编译器一起安装在/ doc子目录中。 为了将变量放在所需的内存中,首先选择将决定所有变量默认位置的内存模型,然后使用@tiny和@near关键字覆盖所选变量的标准选项: char var1; //将进入页零或16位寻址,具体取决于内存模型 @tiny char var2; //无论内存模型如何,都将进入第0页 @near char var3; //无论内存模型如何,都将进行16位寻址 问候, 卢卡(宇宙) 以上来自于谷歌翻译 以下为原文 Hello, the user manual is installed together with the compiler, in the /doc subdirectory. In order to put your variables in the memory you want, first choose the memory model that will decide where all the variables go by default, and then override the standard choice for selected variables by using the @tiny and @near keywords: char var1; // will go in page zero or 16-bit addressing, depending on the memory model @tiny char var2; // will go in page zero regardless of the memory model @near char var3; // will go in 16 bit addressing regardless of the memory model Regards, Luca (Cosmic) |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:57 , Processed in 0.660350 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3659
