电子发烧友论坛|
在STM8S003上:
当我向eeprom写一个页面时,它偶尔似乎会导致CPU的锁定。当我用勺子检查时,它似乎完成了写入但是毫秒后发生了锁定。如果在写入eeprom期间禁用中断,则无效。 以上来自于谷歌翻译 以下为原文 On an STM8S003: When I write a page to eeprom it sporadically seems to cause a lockup of the CPU. When I check with a scoop it seems to finish the writing but milliseconds thereafter a lockup happens. It does not help if I disable interrupts during the writing to eeprom. |
5个回答
请注意,我不使用EEPROM EOP中断。
以上来自于谷歌翻译 以下为原文 Note that I do not use the EEPROM EOP interrupt. |
如果它类似于STM32,当你尝试从FLASH执行同时擦除/写入正在进行时,它只会填充等待状态,从而导致系统完全停顿。外设将保持时钟,但如果不提供实时需求,则会发生上溢/下溢。
在STM32上,您可以通过从RAM运行代码或使用双库闪存来避免这种情况。 以上来自于谷歌翻译 以下为原文 If it is anything like the STM32, it just stuffs wait-states when you try to execute from FLASH while an erase/write is in progress, causing a complete stall of the system. Peripherals will keep clocking, but will overflow/underflow if real time needs are not serviced. On the STM32 you avoid this by running code from RAM, or having a dual-bank flash. |
EERPOM写例程是从RAM执行的,因为我使用STM8S003,它不能从Flash执行EEPROM例程。
以上来自于谷歌翻译 以下为原文 The EERPOM write routines are execute from RAM as I use the STM8S003 which can not execute EEPROM routines from Flash. |
我以一种无望的方式解决了这个问题。最初我认为其他中断可能会在CPU停止并忙于写入eeprom时锁定CPU。因此,为了验证这一点,我在写入eeprom之前禁用了中断,并在写入完成后启用了它们。这没有用。有什么帮助,当我在写入eeprom期间禁用像ADC这样的个别中断时,问题就解决了。我无法解释原因。
以上来自于谷歌翻译 以下为原文 I have solved the problem in an un-expected way. Initially I thought that other interrupts could lock the CPU while it was stalled and busy writing to the eeprom. So to verified this I disabled interrupts before the write to eeprom and enabled them after the write was finished. This did not help. What did help is that when I disabled individual interrupts like the ADC from happening during the write to eeprom and the problem was solved. I can not explain why. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:54 , Processed in 0.838872 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2080
