电子发烧友论坛|
嗨,
我目前正在尝试将MotionEC库用于E-Compass应用程序,并使用MotionMC库校准磁力计。我正在使用带有LSM303AGR的STM32L1-DISCO。我的一般想法是运行校准算法x秒,然后获取校准参数,并将它们应用于电子罗盘计算。 MotionEC库工作得非常好,但我遇到了MotionMC库的麻烦。 首先,我正在运行MotionMC_Update函数,其中包含我从磁力计读取的参数。之后,我正在调用MotionMC_GetCalParams来获取校准参数。但是库总是返回以下默认值: HI_Bias = {0,0,0}, SF_Matrix = {{1,0,0},{0,1,0},{0,0,1}}, CalQuality = MMC_CALQSTATUSUNKNOWN 这是我的代码(基于ST示例)。 // COMPASS_REPORT_INTERVAL = 20 //每隔20ms调用一次 void doCalibrationStep() { SensorAxes_t mag_data_uncompensated; getMagneto(安培; mag_data_uncompensated); MMC_Input_t data_in; data_in.Mag [0] =(float)mag_data_uncompensated.AXIS_X / 10.0f; data_in.Mag [1] =(float)mag_data_uncompensated.AXIS_Y / 10.0f; data_in.Mag [2] =(float)mag_data_uncompensated.AXIS_Z / 10.0f; data_in.TimeStamp = timestamp * COMPASS_REPORT_INTERVAL; //示例data_in:Mag = { - 64,5.5,17.1000004},TimeStamp = 0 MotionMC_Update(安培; DATA_IN); MMC_Output_t data_out; MotionMC_GetCalParams(安培; DATA_OUT); dbg('CalParams X:%f,Y:%f,Z:%f,质量:%d r n',data_out.HI_Bias [0],data_out.HI_Bias [1], data_out.HI_Bias [2],data_out.CalQuality); //无论我多久运行算法时间戳++,一切都有默认值; } void doCalibration() { MotionMC_Initialize(COMPASS_REPORT_INTERVAL,1); char lib_version [200]; MotionMC_GetLibVersion(lib_version); DBG(lib_version); //这里打印正确的版本< doCalibrationStep()以20ms的间隔重复调用,直到x秒过去> MotionMC_GetCalParams(安培; cal_params); //所有参数均为零 } 我完全不知道什么是错的。我错过了什么吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I'm currently trying to use the MotionEC library for an E-Compass application, and to calibrate the Magnetometer with the MotionMC library. I'm using an STM32L1-DISCO with an LSM303AGR. My general idea is to run the calibration algorithm for x seconds, then get the calibration parameters, and apply them to the e-compass calculation. The MotionEC library works perfectly fine but I ran into troubles with the MotionMC library. At first, I'm running the MotionMC_Update function with the parameters I'm reading from the Magnetometer. After that, I'm calling MotionMC_GetCalParams to get the calibration parameters. But the library is always returning the following default values: HI_Bias = {0, 0, 0}, SF_Matrix = {{1, 0, 0}, {0, 1, 0}, {0, 0, 1}}, CalQuality = MMC_CALQSTATUSUNKNOWN Here is my code (based on the ST examples). // COMPASS_REPORT_INTERVAL = 20 // gets called every 20ms void doCalibrationStep() { SensorAxes_t mag_data_uncompensated; getMagneto(&mag_data_uncompensated); MMC_Input_t data_in; data_in.Mag[0] = (float) mag_data_uncompensated.AXIS_X / 10.0f; data_in.Mag[1] = (float) mag_data_uncompensated.AXIS_Y / 10.0f; data_in.Mag[2] = (float) mag_data_uncompensated.AXIS_Z / 10.0f; data_in.TimeStamp = timestamp * COMPASS_REPORT_INTERVAL; // example data_in: Mag = {-64, 5.5, 17.1000004}, TimeStamp = 0 MotionMC_Update(&data_in); MMC_Output_t data_out; MotionMC_GetCalParams(&data_out); dbg('CalParams X: %f, Y: %f, Z: %f, Quality: %drn', data_out.HI_Bias[0], data_out.HI_Bias[1], data_out.HI_Bias[2], data_out.CalQuality); // everything has default values, no matter how often I run the algo timestamp++; } void doCalibration() { MotionMC_Initialize(COMPASS_REPORT_INTERVAL, 1); char lib_version[200]; MotionMC_GetLibVersion(lib_version); dbg(lib_version); // here the correct version is printed MotionMC_GetCalParams(&cal_params); // all parameters are zero } I have absolutely no clue what's wrong. Do I miss something? Thanks |
2个回答
您是否通过3D空间以八字形图案缓慢旋转传感器?
或者您可以沿每个轴旋转它。 在此运动后,您应该获得校准值。 以上来自于谷歌翻译 以下为原文 Did you rotate the sensor slowly in a figure eight pattern through 3D space? Or you can rotate it along each axis. After this movement you should get the calibration value. |
我在过去几周没有时间看这个问题,但是今天有时间进一步调查。
对于可能遇到此问题的用户: 问题在于,在可以读取校准值之前,校准算法必须经常运行。根据间隔,这需要一些时间,在我的情况下> 10秒。我只运行校准算法几秒钟,因此没有得到结果。 以上来自于谷歌翻译 以下为原文 I did not have time in the last few weeks to look at this issue, but found time today to investigate further. For users that might encounter this problem: The problem, was/is that the calibration algorithm has to run quite often before one can read calibration values. Depending on the interval, this takes some time, in my case >10 seconds. I ran the calibration algorithm for a few seconds only and, thus, did not get results. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 05:21 , Processed in 0.623990 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2452
