电子发烧友论坛|
我发现在LA sw v5.30中,如果激活“馈通”模式,则无法通过Setup Config或Setup& Data(.ala)存储调用外部触发输出设置 - 它是否正确?
“Polarity”设置没有那种问题。 16902B帧...每次进入设置 - >外部触发菜单都不方便,并手动更改! 编辑:Alx于2012年6月15日10:48 AM编辑:Alx于2012年6月15日上午10:49 以上来自于谷歌翻译 以下为原文 I found in LA sw v5.30 it is not possible to store-recall by Setup Config or Setup&Data (.ala) an External Trigger Output setting, if "Feedthrough" mode activated - is it correct functionality ? "Polarity" setting is has no problem of that kind. 16902B frame... It is not convenient to go every time to Setup -> External Trigger Menu, and change it manually! Edited by: Alx on Jun 15, 2012 10:48 AM Edited by: Alx on Jun 15, 2012 10:49 AM |
3个回答
附上一些照片。
使用2x16950B-64模块(1x16950B-64配置有同样的问题)。 我认为这是LA软件的一些错误,外部触发设置不会保存到安装配置。 Sampling.PNG20.3 KBExt_trigger_when_setup_and_data_restored.PNG16.0 KBExt_trigger_on_saving_setup_and_data.PNG16.5 KB 以上来自于谷歌翻译 以下为原文 Some pics attached. 2x16950B-64 module used (1x16950B-64 configuration has the same problem). I think that is some bug of LA software, External Trigger setting is not saved to Setup configuration. 附件
毛新宇的儿子王大锤 发表于 2019-3-28 15:20 是的,这是一个错误,并且已经进入系统进行修复,其他设置在几个修订版之前添加到外部触发器配置窗口,并且通过疏忽,这些设置未添加到配置文件中。 加载文件时,没有为这些设置加载任何内容,因此它们将恢复为默认值。 它将在某个时候修复,但我没有计划的日期。 人 以上来自于谷歌翻译 以下为原文 Yes, it's a bug, and has been entered into the system for repair, Additional settings were added to the External Trigger configuration window a few revisions ago, and through an oversight, those settings were not added to the configuration file. When you load a file, nothing is loaded for those setting, so they revert to the defaults. It will be repaired at some point, but I don't have a planned date. Al |
nvywyerwer 发表于 2019-3-28 15:39 非常感谢你! 以上来自于谷歌翻译 以下为原文 Thank you very much! |
只有小组成员才能发言,加入小组>>
1846 浏览 0 评论
2740 浏览 1 评论
2641 浏览 1 评论
2451 浏览 5 评论
3461 浏览 3 评论
1846浏览 0评论
418浏览 0评论
/9
GMT+8, 2025-12-3 02:57 , Processed in 0.776991 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1437
