电子发烧友论坛|
大家好,我的名字是Cosimo,我需要有关步进驱动程序的帮助。
从一台旧打印机我得到了一个双极步进器,现在我正试图用L298和L297配置驱动它。步进输出,L298的输出为:0V 12V 0V 12V。没关系!但是对于电机,L298的输出为:6V 6V 6V 6V。为什么这个? 测试L297输出我没有电机:引脚4 0V,引脚6 4.4V,引脚5 4.4V,引脚7 0V,引脚9 4.4V,引脚8 4.4V。 测试L297输出我用电机:引脚4 0V,引脚6 4.4V,引脚5 2.2V,引脚7 0V,引脚9 4.4V,引脚8 2.2V。 提前致谢。 科西莫 #L298-L297 以上来自于谷歌翻译 以下为原文 Hi to all, my name is Cosimo and I need help about stepper driver. From an old printer I've get a bipolar stepper and now I'm trying to drive it with L298 and L297 configuration. Whitout the stepper the output of L298 are: 0V 12V 0V 12V. It's ok! But with the motor the output of L298 are: 6V 6V 6V 6V. Why this? Testing the L297 output I've without the motor: pin 4 0V, pin 6 4.4V, pin 5 4.4V, pin 7 0V, pin 9 4.4V, pin 8 4.4V. Testing the L297 output I've with the motor: pin 4 0V, pin 6 4.4V, pin 5 2.2V, pin 7 0V, pin 9 4.4V, pin 8 2.2V. Thanks in advance. Cosimo #l298-l297 |
3个回答
解决了!当启动条件为0101且步进电压为12V时,步进电压为6V是正常的..问题是电路板(驱动器L297 + L298和PIC32入门工具包)之间的接地连接和时钟速度为高...感谢所有。
以上来自于谷歌翻译 以下为原文 solved! 6V are normal in stepper when the start condition is 0101 with 12V supply of stepper.. the problem was ground connection between boards (driver L297+L298 and PIC32 starter kit) and clock speed to high.. thanks to all. |
我是一名电气工程专业的学生。我只想问是否需要将光隔离器与L298连接?它没有内置保护吗?
我正在使用带有NXT乐高电机的STM32F303微控制器。电机规格如下: 失速电流:2A 自由运行电流:60mA 以上来自于谷歌翻译 以下为原文 I am an Electrical Engineering student. I just wanna ask whether is there any need to connect optoisolator with L298? Doesn't it has built in protection? I am using STM32F303 microcontroller with NXT lego motors. Specs of motors are: Stall current: 2A Free running current: 60mA |
嗨,
通常在这种应用中不需要光隔离器。 L298集成了热保护功能,您指出的电流额定值均在IC的安全范围内。 恩里科 以上来自于谷歌翻译 以下为原文 Hi, Usually optoisolator are not required in this kind of applications. The L298 integrates thermal protection and the current ratings you indicated are within the safety ranges of the IC. Enrico |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:17 , Processed in 1.130162 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1953
