嗨,所有的,我试图提出一个自定义板,这是基于PIC32 MZ2048 EFH144以太网启动套件,即相同的24MHz晶体,但不同的设备。系统运行在200兆赫。如果我试图调试使用ICD 3,我得到以下信息:我可以让它使用内部OSC工作这里是我的设置与外部时钟-恰巧是相同的使用以太网起动器套件。有任何想法为什么这不起作用?谢谢。
以上来自于百度翻译 以下为原文 Hi All, I'm attempting to bring up a custom board which is based upon the PIC32MZ2048EFH144 Ethernet starter kit i.e. same 24MHz crystal but different device. The system is running at 200MHz. If I attempt to debug using the ICD 3 I get the following message:Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x1bfff boot config memory configuration memory Programming/Verify complete The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings. I can make it work by using the internal oscillator. Here are my settings with the external clock - which happen to be exactly the same as using the Ethernet starter kit. /*** DEVCFG0 ***/ #pragma config DEBUG = OFF #pragma config JTAGEN = OFF #pragma config ICESEL = ICS_PGx2 #pragma config TRCEN = OFF #pragma config BOOTISA = MIPS32 #pragma config FECCCON = OFF_UNLOCKED #pragma config FSLEEP = OFF #pragma config DBGPER = PG_ALL #pragma config SMCLR = MCLR_NORM #pragma config SOSCGAIN = GAIN_2X #pragma config SOSCBOOST = ON #pragma config POSCGAIN = GAIN_2X #pragma config POSCBOOST = ON #pragma config EJTAGBEN = NORMAL #pragma config CP = OFF /*** DEVCFG1 ***/ #pragma config FNOSC = SPLL #pragma config DMTINTV = WIN_127_128 #pragma config FSOSCEN = OFF #pragma config IESO = OFF #pragma config POSCMOD = EC #pragma config OSCIOFNC = OFF #pragma config FCKSM = CSECME #pragma config WDTPS = PS1048576 #pragma config WDTSPGM = STOP #pragma config FWDTEN = OFF #pragma config WINDIS = NORMAL #pragma config FWDTWINSZ = WINSZ_25 #pragma config DMTCNT = DMT31 #pragma config FDMTEN = OFF /*** DEVCFG2 ***/ #pragma config FPLLIDIV = DIV_3 #pragma config FPLLRNG = RANGE_5_10_MHZ #pragma config FPLLICLK = PLL_POSC #pragma config FPLLMULT = MUL_50 #pragma config FPLLODIV = DIV_2 #pragma config UPLLFSEL = FREQ_24MHZ /*** DEVCFG3 ***/ #pragma config USERID = 0xffff #pragma config FMIIEN = OFF #pragma config FETHIO = ON #pragma config PGL1WAY = ON #pragma config PMDL1WAY = ON #pragma config IOL1WAY = ON #pragma config FUSBIDIO = ON /*** BF1SEQ0 ***/ #pragma config TSEQ = 0x0000 #pragma config CSEQ = 0xffff Any ideas why this does not work? Thanks. |
6个回答
你的板上有水晶吗?还是振荡器芯片?晶体需要由PIC驱动,因为振荡器具有所有的自包含,并且仅输出一个方波。起动器工具包使用振荡器芯片。因此,“EC”(外部时钟)POSCMOD。如果你实际使用的是水晶,那么你需要将你的模式改变为高速水晶的“HS”。在EC模式下,你的水晶没有振荡的方式(通常)!最后,请注意PIC32 MZ系列振荡器的勘误表(勘误表2)修订版A1硅:晶体振荡器不能用作主振荡器(OSC1/OSC2管脚)的输入。修订版A3硅:主振荡器已在正常的上电序列中测试过。支持特定的晶体操作。
以上来自于百度翻译 以下为原文 Do you have a Crystal on your board? Or an Oscillator chip? A crystal needs to be driven by the PIC, where as an oscillator has all of that self contained and just outputs a square wave on its own. The starter kit is using an Oscillator chip. Hence, the "EC" (external clock) POSCMOD. If you are actually using a Crystal, then you need to change your mode to "HS" for High Speed Crystal. In EC mode, your crystal has no way to oscillate (normally! see errata below). Finally, note the errata for the PIC32MZ family for the oscillator: (Errata 2) Revision A1 Silicon: A crystal oscillator cannot be used as an input to the Primary Oscillator (OSC1/OSC2 pins). Revision A3 Silicon: The Primary Oscillator has been tested in a normal power-up sequence and supports specific crystal operation. |
“我试图提出一个定制板,它是基于PIC32 MZ2048 EFH144以太网启动器套件,即相同的24MHz晶体,但不同的设备。”正如所指出的,以太网启动器套件没有晶体。它有一个时钟振荡器IC。
以上来自于百度翻译 以下为原文 "I'm attempting to bring up a custom board which is based upon the PIC32MZ2048EFH144 Ethernet starter kit i.e. same 24MHz crystal but different device. " As Pointed out the Ethernet starter kit does not have a crystal. It has a clock oscillator IC. |
嗨,1 /如果你使用XTAL,改变配置位符合。2/确保你为你的PIC32 MZ2048 EFH100选择了正确的调试接口,你把ICSP连接到PGC2/PGD2了吗?如果不是,你需要根据你的观点来改变
以上来自于百度翻译 以下为原文 Hi, 1/ If you use an XTAL, change the configuration bits accordingly. 2/ Make sure that you selected the right debug interface # for your board PIC32MZ2048EFH100. Did you connect the ICSP to the PGC2 / PGD2 ? if not you need to change the #pragma config ICESEL = ICS_PGx2 accordingly Regards |
如果您正在使用XTAL:请阅读Erratta:http://WW1.Microchip .com……EVICEDOC/8000 66 3D.PDF
以上来自于百度翻译 以下为原文 If you are using an Xtal: Read the Erratta: http://ww1.microchip.com/...eviceDoc/80000663D.pdf |
当您编程的芯片有一个修订提供。如果是A1,那么晶体不起作用。如果是A2,你需要一个电阻器来记录勘误表。从DigiKy剪辑磁带是两个星期前的一部分。我现在转而使用一个振荡器,现在只有安全的方法。比尔
以上来自于百度翻译 以下为原文 When you program the chip there is a revision provided. If it is A1 then a crystal does not work. If it is A2 you need a resistor IAW the ERRATA. Cut tapes from digikey were A1 parts twp weeks ago. I am relaying out to use an oscillator, only safe way for now. Bill |
感谢所有回答的人。是的,它是水晶。这将是一个振荡器集成电路作为起动器工具包。现在我将继续使用内部振荡器。再次感谢。
以上来自于百度翻译 以下为原文 Thanks to all who replied. Yes it is a crystal. This is will be swapped out for an oscillator IC as per the starter kit. For now I'll continue using the internal oscillator. Thanks again. |
只有小组成员才能发言,加入小组>>
5079 浏览 9 评论
1954 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3115 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2186 浏览 5 评论
633浏览 1评论
506浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
370浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
535浏览 0评论
440浏览 0评论
GMT+8, 2024-9-28 18:25 , Processed in 1.214417 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
