您好,我试图创建一个新的32位MPLAB和谐项目。在选择了Target DevicePIC32MZ2048EFH144(因为它在我的PIC32MZ(EC)启动器套件上)之后,我试图选择PIC32MZ(EC)启动器套件。MPLAB X然后将目标设备更改为PIC32MZ2048ECM144。在0种配置(例如USAT)上,应用程序有错误。有人能帮助吗?谢谢!
以上来自于百度翻译 以下为原文 Hello, I try to create a new 32-bit MPLAB HARMony Project. After selecting Target Device PIC32MZ2048EFH144 (as it is on my PIC32MZ(EC) Starter Kit), I try to select PIC32MZ (EC) Starter Kit. MPLAB X then changes the Target Device to PIC32MZ2048ECM144. When I try to create a Project with Harmony's Application 0 Configuration (e.G. Usart) the Application has faults. Can anyone help. Thanks loupdethies |
2个回答
你想设置BSP吗?那个董事会有几种方式,你选对了吗?选择BSP后,可以将其更改为正确的芯片吗?应用程序中的错误很少提供有用的信息。
以上来自于百度翻译 以下为原文 Are you trying to set the BSP? That board is available several ways did you select the right one? Can you change it to the correct chip after you select the BSP? The application has faults conveys little useful information. |
你好,看起来你可能对PIC32 MZ EC和MZ EF感到困惑。请注意,这些是不同的数据表不同的设备。有一些外围差异。这两个设备都有一个BSP,所以您应该选择一个适用于您的设置的BSP。这些是密码引擎的不同之处。对于一些地点,他们只能装运非加密版本。在大多数情况下,针对哪个设备并不重要,因为除了安全性之外,没有外围差异。在编写设备时,您可能会收到一条消息,但是您可以继续执行此操作,并且您的代码应该可以正常工作。
以上来自于百度翻译 以下为原文 Hello, It seems you may be confused about the PIC32 MZ EC and the MZ EF. Please realize these are different devices with different data sheets. There are a number of peripheral differences. There is a BSP for both of these devices, so you should select the one that applies to your setup. For differences within the family, for example the MZ EC H vs. the MZ EC M... these are differences for the crypto engine. For some locations they can only be shipped the non-crypto version. In a majority of cases, it will not matter which device you target as there are no peripheral differences other than for security. You may get a message when programming the device, but you can proceed through this and your code should work. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
508 浏览 0 评论
5813 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-14 16:05 , Processed in 1.018788 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3757
