电子发烧友论坛|
大家好,
我使用TX8通过RS232发送数据。在labview API上接收数据。当接收到值时,我会遇到问题,因为LabVIEW无法检测终结符图表。当我在TX8的数据表中读取时,函数TX8Y-PUTCRL发送了0x0d('r')和0x0a('n)。在我发送数据的值之后,我把它放在这个函数中。 哪一个终止图决定每个数据? 谢谢你的反馈! 以上来自于百度翻译 以下为原文 Hi everyone, I'm using the TX8 to send data through RS232. the data is received on Labview API. I have problems when the value is recieved there, because is like Labview no detect the terminator chart. As I read in the datasheet of TX8 the function TX8_PutCRL send an 0x0D ('r') and 0x0A ('n'). I put it this function after I send the value of the data. Which terminator chart determine every data? Thanks for your feedbacks! |
6个回答
你好,
一个音符: 我用超级终端测试它,看看传输是否正常运行。所以,我不明白为什么TEMIN会话运行良好,LabVIEW没有。 谢谢你的反馈! 以上来自于百度翻译 以下为原文 Hi, One note: I tested it with Hyperterminal to see if the transmission works, and runs properly. So, I don't understand why with teminal session runs well and with Labview not. Thanks for your feedbacks! |
为什么不在LabVIEW中捕获原始数据并分析哪些值正在被接收。一旦你有了原始数据,那么你就可以很容易地添加一个条件来比较是否已经接收到终结符。
最好的问候, 加内什 以上来自于百度翻译 以下为原文 Why dont you just capture the raw data in Labview and analyze what values are being received. Once you have the raw data, then you can easily add a condition to compare if the terminator has been received. Best Regards, Ganesh |
嗨,Graa,
我已阅读,有必要把一个MAX232 PSoC DB9输出和PC的DB9输入之间是为什么我不能收到正确的数据在LabVIEW? 谢谢你的反馈! 以上来自于百度翻译 以下为原文 Hi Graa, I have been reading that is necessary to put a MAX232 between the PSOC DB9 output and the DB9 input of the PC. Is why I can't recieve the data properly in labview? Thanks for your feedbacks! |
对。为了与PC进行可靠的通信,必须将TTL电平信号从PSoC转换为PC.的RS232电平信号,因为这需要使用像Max 232这样的收发器。
如果你看到超级终端中的字符(可能是接口与TTLLAMP的边缘工作),那么你也应该能够在LabVIEW中看到它们。因此,除了使用Mx23驱动芯片之外,您还可能需要麻烦地解决LabVIEW通信方面的问题。 最好的问候, 加内什 以上来自于百度翻译 以下为原文 Yes. For reliable communication with PC, you have to translate the TTL level signals from PSoC to RS232 level signals of PC. For this you need to use a transceiver like MAX232. If you are seeing the characters in Hyperterminal (maybe the interface is working marginally with the TTL signals), you should be able to see them in Labview as well. So, apart from using MAX232 driver chip, you may have to trouble shoot the Labview side of communication as well. Best Regards, Ganesh |
你好,
谢谢! 这是LabVIEW的问题…但是,它运行良好,没有MAX22…我猜是发生在你告诉我在你的最后一个帖子! 非常感谢你的支持! 以上来自于百度翻译 以下为原文 Hi, Thanks graa! It was a problem of Labview... However it runs well without MAX232...I guess is happening what you told me in your last post ! Thanks so much for your support! |
我也有麻烦使用LabVIEW收集数据通过COM端口。解决这个问题的方法是什么?
以上来自于百度翻译 以下为原文 I have also had trouble using Labview to collect data over the com port. What was the solution to get this working? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 05:01 , Processed in 0.735755 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1050
