嗨,大家好,
(我也在PSoCeDeCurror网站上发布了这篇文章,所以请原谅我的重复!) 我想听到任何人成功地将嵌入式PSoC 3或PSoC 5设备应用到生产构建中。原因是我打算把我的设计从beta转变为生产。在beta期间,我一直使用PSoC3和PSoC5 FTK模块插入到我的板上的标题中。为了生产,我想摆脱FTK模块,并将PSoC5芯片直接嵌入到我的设计中。具体地说,我想了解有关实施SWD的任何问题——您提出了哪些SWD/RESET PIN,哪种类型的报头,以及哪一个程序员用于调试和编程?你仍然可以在PSoC Creator内部编程和调试你的设备吗?在你的设计中嵌入了USB程序员吗?我是否应该把PSoC SWD引脚带到一个头上,或者仅仅嵌入FX2LP USB芯片?如果是这样,大概FX2也需要一些固件在里面,我怎么编程呢?我很感激任何已经做过这件事的人的建议。 以上来自于百度翻译 以下为原文 Hi All, (I have also posted this over at PSoCDeveloper.com, so please forgive me for the duplication!) I would be interested in hearing from anyone who has successfully implemented an embedded PSoC 3 or PSoC 5 device into a production build. The reason is that I am about to move my design from BETA to Production. During Beta I have been using PSoC3 and PSoC5 FTK modules plugged into a header on my board. For production I would like to get rid of the FTK module and embed the PSoC5 chip directly into my design. Specifically I would like to hear about any issues surrounding implementing SWD - which SWD/RESET pins did you bring out, what type of header, and which programmer do you use for debug and programming? Can you still program and debug your device from within PSoC Creator? Did you embed a USB programmer into your design? Should I just bring out the PSoC SWD pins to a header; or just embed the FX2LP USB chip? If so then presumably the FX2 will need some firmware inside it also, how do I program that? I am grateful for advice from anyone who has done this already. |
4个回答
嗨,肯尼,
出于生产的目的,我们有一个认证的第三方程序员在赛普拉斯网站上支持PSoC 3编程。但是他们只能从他们自己的程序员GUI编程PSoC 3。唯一可以从PSoC Creator环境中使用的程序员/调试器是在FTK,-030 DVK中支持的MIXPRO3和FX2LP。PSoC Creator现在还不支持第三方程序员或调试器从其环境中获得支持。 话虽如此,我已经为PSoC 1开发了一种PSoC 3版本的HSSP应用说明(AN44 168是PSoC 1 HSSP)。该项目将使用PSoC 5作为主机来编程PSoC 3。它遵循AN623 91中提到的编程规范。我们将在本月底之前发布。如果你想早点拷贝,请将你的电子邮件ID详细信息发送到“VVSK@ CyPress网站”(它是2 V,而不是电子邮件ID中的W)。我可以把草稿给你,项目。 关于PSOC 3编程的硬件连接,请参阅AN62691。AN64 359相当于PSoC 5。希望这有帮助。如果你有进一步的问题,请告诉我。 谢谢, 维韦克 以上来自于百度翻译 以下为原文 Hi Kenny, For production purposes, we have a list of certified third party Programmers on Cypress website that support PSoC 3 programming. But they can only program PSoC 3 from their own Programmer GUI. The only Programmer/Debuggers which can be used from PSoC Creator environment is Miniprog3 and FX2LP based one supported in FTK's, -030 DVK's. PSoC Creator right now is not yet supporting third party PRogrammer or Debugger from its environment. Having said that, I have developed a PSoC 3 version of HSSP Application note for PSoC 1 (AN44168 is PSoC 1 HSSP). This project will use PSoC 5 as a Host to program PSoC 3. It follows the Programming specifications mentioned in AN62391. We will be releasing it before end of this month. If you want a copy earlier, please send your email id details to "VVSK@CYPRESS.COM" (it is 2 V's and not W in email id :) ). I can send you the draft document, project. Regarding the hardware connections for PRogramming PSoC 3, refer AN62391. AN64359 is equivalent for PSoC 5. Hope this helps. Let me know if you have further questions. Thanks, Vivek |
你也可以参考应用笔记AN61291在HTTP://wwwyCysP.com/?RID=43337连接器详细信息。
以上来自于百度翻译 以下为原文 You can also refer to application note AN61291 at http://www.cypress.com/?rID=43337 for connector details. |
对不起,这是打字错误。一个数字是AN61290:硬件启动指南与PSoC Creator。第4、5页讨论编程、调试接口。
以上来自于百度翻译 以下为原文 Sorry it is a typo. The AN number is AN61290:Hardware starting guide with PSoC Creator. Pages.4,5 talk about Programming, Debug interfaces. |
谢谢你的回复。
我将阅读你提到的申请说明: 以上来自于百度翻译 以下为原文 Thanks for the replies. I shall read the application notes you mentioned :-) |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:45 , Processed in 0.754789 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1397
