电子发烧友论坛扫一扫,分享给好友
我一直使用PSoC 3成功几个月,但现在有一个链接问题升级到贝塔5。
我得到这个错误信息:L220:无效的输入模块 它指的是一个名为CBCySLav.LIB的文件。这是我的项目名称,但是我找不到项目设置中的“LIB”文件的任何引用,所以我不知道这个文件应该从哪里来。 还有其他人有这个问题吗?有什么办法解决吗? 谢谢,吉姆 以上来自于百度翻译 以下为原文 I have been using the PSoC 3 successfully for a couple of months, but now have a linker problem after upgrading to Beta 5. I get this error message: L220: INVALID INPUT MODULE It is referring to a file named CBC_Slave.LIB. This is my project name, but I can't find any reference to a "LIB" file in the project settings, so I don't know where this file is supposed to come from... Has anyone else had this problem? Any ideas how to fix? Thanks, Jim |
4个回答
更新。
我发现了一些关于这个问题的东西,我认为它应该被视为一个bug。 首先,在调用链接器之前,PSoC Creator生成的调用LIbx51.EXE的命令行不在该行的末尾在目标LIB文件名周围放置引号。我几乎从不在文件或目录名中放置空格,但是Windows在复制文件夹时执行,并且我正在从复制的文件夹中工作。重新命名文件夹以移除空格使LIXX51工作。 一个相关的问题似乎是针对Link,LX51.EXE生成的命令行。以前的LIbx51调用对LIB文件的引用是使用相对文件路径引用的,但我能真正告诉它什么?链接器显然找不到文件。我已经试过看可能影响这个项目的设置,但是没有什么能跳过我。 当我复制-修改-将生成的行粘贴到命令提示符时,它们似乎起作用了… 当然,在开始这篇文章之前,我试图用链接器重现早期的成功,但现在我无法使它成功。我发布这篇文章,至少让其他人思考PSoC Creator内部的命令行生成。 谢谢,吉姆 以上来自于百度翻译 以下为原文 Update. I have found out some things about this problem, and I think it should be treated as a bug. First of all, the command line generated by PSoC Creator to call LIBX51.EXE, just before calling the linker, does not put quotation marks around the destination LIB file name at the end of the line. I almost never put spaces in file or directory names, but Windows does when copying a folder, and I was working from a copied folder. Renaming the folder to remove spaces makes LIBX51 work. A related problem seems to be with the command line generated for the linker, LX51.EXE. The reference to the LIB file generated by the previous LIBX51 invocation is referenced using a relative file path, but I can really tell relative to what? The linker apparently can't find the file. I have tried looking at project settings that might affect this, but nothing jumps out at me. When I copy - modify - paste the generated lines onto a command prompt, they seem to work... Of course, before commiting this post I tried to reproduce earlier success with the linker, but now I can't make it work. I am posting this anyway to at least get some other people thinking about the command line generation inside of PSoC Creator. Thanks, Jim |
另一个有趣的信息是,这个问题开始我升级到cy_boot V 2.0;我升级所有其他模块没有问题…所以,这实际上可能没有任何链接器命令行…
以上来自于百度翻译 以下为原文 Another tidbit of info is that this problem started with I upgraded to cy_boot v 2.0; I upgraded all other modules without problems... So, this in fact may have nothing to do with linker command lines... |
我的版本:
环境: PSoC创建者1生产(1.0.0.77 27) 文化:法语(法国) 操作系统版本:微软Windows NT 5.1.2600 Service PACK 3 CLR版本:2.0.50727.3603 安装的CyStor产品: PSoC程序员3.124制作 PSoC创建者1生产 PSoC开发工具包1 PSOC开发包CY8C55 1 Rev*A 以上来自于百度翻译 以下为原文 My version : Environment: PSoC Creator 1.0 Production (1.0.0.7727) Culture: French (France) OS Version: Microsoft Windows NT 5.1.2600 Service Pack 3 CLR Version: 2.0.50727.3603 Installed CyInstaller Products: PSoC Programmer 3.12.4 Production PSoC Creator 1.0 Production PSoC Development Kit 1.0 Rev*E PSoC Development Kit CY8C55 1.0 Rev*A |
你好朋友们
我刚刚开始在PSoC3编程,但是我遇到了这样的问题。我也安装了Keil的更新版本,但是仍然有问题。如果有人解决这个问题,请尽快指导我。 提前感谢。 PSOC3.PNG 134.2 K 以上来自于百度翻译 以下为原文 Hello Friends I am Just starting to programming in Psoc3 .but I Have some problem like this. I am also Install the Update version of Keil .But still having the problem. Please guide me soon if any one has solution of this. Thanks in Advance.
只有小组成员才能发言,加入小组>>
787个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7297 浏览 0 评论
2484 浏览 1 评论
2178 浏览 1 评论
4041 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2086 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7798浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6360浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
756浏览 2评论
729浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8205浏览 2评论
/9
GMT+8, 2025-12-11 21:57 , Processed in 0.630122 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6362
