嗨,大家好,
我遇到了ADC14的问题。 当PSoC的暖和,ADC14阅读突然下降明显,停留下来直到芯片冷却下来。我有一个电阻与输入简单的设计,不应该发生的。电压应稳定在5.00伏。 我可以通过加热PSoC的热空气和冷却下来,再次证明了好几次。 我说的开始温度20℃(常温)和最高温度50摄氏度(不要太烫)。跳动发生在摄氏40度左右。 直到现在我也不排除我有板的另一个设计问题,但我认为这可能与ADC的设置问题。 请你让我知道我会遇到什么问题? 最好的问候, 乌龟 以上来自于百度翻译 以下为原文 Hi all, I am stuck with a problem with the ADC14. When the PSOC gets wARM, the reading of the ADC14 suddenly drops down a significant number and stays down until the chip has cooled down again. I have a simple PT1000 with a resistor attached to the input, nothing should happen there. The voltage should be stable at 5.00V. I could prove this several times by heating the PSOC with hot air and cooling it down again. I am talking about a start temperature of 20 degrees centigrade (normal room temperature) and a top temperature of 50 degrees centigrade (not too hot). The jump happens at around 40 degrees centigrade. Until now I can not exclude that there is another design problem on my board, but I think this may be a problem with the ADC or its settings. Could you please let me know what problem I might have run into? Best regards, Turtle |
5个回答
泰伦斯!
你能解释一下你的意思吗? 当做 以上来自于百度翻译 以下为原文 Terrence! COuld You please explain what You mean? regards |
罗伯特塞克斯科夫斯
这个职位已经一个星期了,也许他已经找到了解决办法。 以上来自于百度翻译 以下为原文 @robertseczkowski, The post is a week old, perhaps he has already found a solution. |
问题仍然存在。
但与此同时,我发现,受影响的电路板比另一块板的电流要大得多,虽然它应该是相同的,但没有显示出这种效果。 仍在调查中。当我找到解决办法时,我会发表意见。 以上来自于百度翻译 以下为原文 The problem is still there. But in the mean time I found out that the affected board takes significantly more current than another board that does not show this effect although it should be identical. Still investigating. I will post when I found the solution. |
很久以前……
但问题仍然存在。 在去年我写的板上,有一个IC放置错了,导致更高的电流。 但是即使在确定之后,测量仍然依赖于温度。 同时,我已经测试了大约30个板,其中3个显示了当板达到大约40摄氏度时,读数下降的现象。 我还测试了“正常”的电路板。当板的温度上升到大约75摄氏度时,它们显示出一滴读数,我认为这是可以接受的。 以上来自于百度翻译 以下为原文 long time ago..., but the problem is still there. On the board I wrote about last year, there was one IC misplaced that lead to the higher current. But even after fixing that, the measurement was still temperature dependent. In the mean time, I have tested about 30 boards, 3 of them show the phenomenon that the reading drops when the board reaches about 40 degrees centigrade. I have also tested "normal" boards. They show a drop of the readings when the board temperature goes up to more than approx 75 degrees centigrade, which I think is acceptable. |
只有小组成员才能发言,加入小组>>
719个成员聚集在这个小组
加入小组1913 浏览 1 评论
1667 浏览 1 评论
3419 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1584 浏览 6 评论
1389 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
210浏览 2评论
195浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
343浏览 2评论
369浏览 1评论
76浏览 1评论
GMT+8, 2024-5-15 14:04 , Processed in 1.135253 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
