电子发烧友论坛|
早上好。
我正在尝试读取连接到功率计4418B的传感器E4413A的CF表,但我无法选择或查看或编辑cf表。 表格选择按钮为“灰色”。 另外,在手册中,它说,cf表是从eeprom下载的。 无法查看或编辑此表。 我可以用SCPI指令做到这一点吗? 谢谢 以上来自于谷歌翻译 以下为原文 Good morning. I am trying to read the CF table of sensor E4413A, connected to a power meter 4418B, but i cannot select or view or edit the cf table. The table selection button is "grayed". Also, in the manual, it says that, the cf table is downloaded from eeprom. This table cannot be viewed or edited. Can i do this with SCPI instructions? Thank you |
2个回答
嗨,尝试附带的程序,他们应该帮助解决你的问题。运行vee - eeprom到文件编程。
(你必须在你的桌面上创建一个名为'DATA'的文件夹。在这个文件中你需要一个名为'ECPDL.txt'的文件.vee prog应该将二进制文件转储到ECPDL中,当你打开这个文件时你应该找到一个coloum 数字,第一个是行号(1到4095),第二个数字是二进制数据。打开excel文件,然后加载ECPDL文件(删除逗号和括号 - 这样当加载到excel时你有多少数字) 这个数据被加载到从单元格A1开始的'作业数据导入'页面。如果一切正常运行,你应该计算并显示在这个页面上的计算因素。祝你好运.RegardsAlan Horner 以上来自于谷歌翻译 以下为原文 Hi, Try the enclosed programs, they shouldhelp to solve your proplem. run the vee - eeprom to file prog first. ( you will have to make a folder called 'DATA', on your desktop.Within this file you require a file called 'ECPDL.txt' The vee prog should dump a binary file into ECPDL, when youopen this file you should find a coloum of numbers, the first is line numbers( 1 to 4095) the second number is the binary data. Open up the excel file, then load the ECPDL file (stripped of comma and brackets - such thatwhen loaded into excel youhave to coloums of numbers)this data is loaded into the 'job data import' page starting at cell A1. If all is running correctly you should then have the cal factors computed and displayed on this page. Good luck. Regards Alan Horner |
帮助这不会让我加载您需要附件的文件。
你是普通/旧的vrf系统吗? 以上来自于谷歌翻译 以下为原文 help this will not let me load the files you require for attachment. Are you on the normal/old vrf system? |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:06 , Processed in 1.997268 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2502
