电子发烧友论坛|
嗨,我有一个问题,我用我的皮卡有一段时间了,今天我试着编程PIC 12F675,我不能。尝试这么多次,我怀疑它不是PIC,所以与另一个测试,一个16F690,我也不能,我担心,我试着用我的所有的微,没有编程任何…给出相同的错误“编程失败在程序内存地址0x000”或编程失败在EE数据ADRES0x00。尝试另一个USB电缆,在另一台笔记本电脑上,它也会发生同样的情况…
以上来自于百度翻译 以下为原文 hi, I have a problem, I have used my pickit for some time and today I tried to program a pic 12f675 and I could not. Try so many times that I suspect that it was not the pic so test with another, a 16f690 and I could not either, I worry and I tried with all my micros and did not program any...Gives the same error "programing failed at program memory address 0x0000" or programing failed at EE data adrress 0x0010"... Try another u*** cable, and on another laptop, and it happens the same... |
17个回答
你是如何连接你的照片的?它们是用ICSP连接器在目标板上吗?或者你有一个带有插件的适配器板,把PIC放到程序中去?是来自董事会还是来自PK3的权力?PK3是直接插入你的笔记本电脑,还是通过集线器?
以上来自于百度翻译 以下为原文 How are you connecting to your PICs? Are they on target boards with an ICSP connector, or do you have an adaptor board with a socket that you put the PIC into to program it? Is power coming from the board or from the PK3? Is the PK3 plugged directly into your laptop, or via a hub? |
一些是在原板上,有2个目标板上的ICSP,我没有适配器…尝试两种形式,从PK3提供电源,也从外部来源或从电路源SPK3直接插入到USB DCOM和笔记本电脑的连接器。
以上来自于百度翻译 以下为原文 Some are on a proto board, and have 2 on target board with ICSP, i dont have adaptor... Try both forms, giving power from pk3 and also from an external source or from the source of the circuits pk3 is direct plugged on u*** conector of de PC and laptop |
PK3固件可能被破坏。尝试选择一个完全不同的家庭设备,例如PIC18F,并让MPLAB更新PK3中的固件来处理它,然后切换回您想要的设备。
以上来自于百度翻译 以下为原文 The PK3 firmware may be corrupted. Try selecting a totally different family device, e.g. PIC18F, and let MPLAB update the firmware in the PK3 to handle that, then switch back to your intended device. |
你尝试过不同的PIC家族来下载新的固件吗?它可能在某种程度上变成了腐败,并且反思它可能会治愈这个问题。我不确定是否有一种方法直接强制反射。打我2分钟!:)
以上来自于百度翻译 以下为原文 Have you tried a different family of PIC to cause a download of new firmware? It could have become corrupted somehow, and reflashing it might cure the problem. I'm not sure if there is a way to force a reflash directly. [edit] Ha! Beat me by 2 minutes! :) |
如果你按下PICTIT3上的按钮,然后插入USB电缆,它迫使它在引导引导器中启动。
以上来自于百度翻译 以下为原文 If you hold down the button on the PICKit3 then plug in the USB cable it forces it to start in its bootloader. |
谢谢你的帮助,我有一个PIC 18F2620和一个18F1320和一个DS30…可以解释,我怎么做这个程序?…使用PICTIT3软件或MPLAB IPE。我必须打开MPLAB X…
以上来自于百度翻译 以下为原文 Thanks for trying to help, I have a pic 18f2620 and a 18f1320 and a ds30 ... could explain, and how do I do this procedure? ... use pickit3 software or mplab IPE. I must have open the Mplab X ... |
当我这样做时,PK3变成兼容的MPLAB IPE。
以上来自于百度翻译 以下为原文 When I do that the pk3 becomes compatible mplab IPE |
当我这样做时,PK3变成兼容的MPLAB IPEIS,在你的情况下是好还是坏?它应该告诉你它正在更新固件。
以上来自于百度翻译 以下为原文 When I do that the pk3 becomes compatible mplab IPE Is that good or bad in your case? It should tell you it is updating the firmware. |
嗨,今天我用PIC18F做了测试,把它连接到PK3软件上说“没有找到设备”…所以我做了我推荐的伙伴,把我的按钮连接到USB上,这是MPLAB IDE消息:连接到MPLAB皮卡3……在PoxIT 3固件SU上当前加载的固件。未知固件类型:下载目标设备的新固件:PIC18F1320下载RS…RS下载完成编程下载…下载AP…AP下载完成编程下载…当前加载的固件在皮卡3固件SUI上TE版本…01.45.41固件类型……PIC18F目标电压检测目标设备ID(0x0)是无效的设备ID。请检查您与目标设备的连接。
以上来自于百度翻译 以下为原文 hi, Today I did the test with pic 18f, To connect it the pk3 software says "no device found"... So I did what I recommend the partner to keep the button down while I connect it to the USB, And this is the MPLAB IDE message: Connecting to MPLAB PICkit 3... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.45.41 Firmware type..............Unknown Firmware Type Now Downloading new Firmware for target device: PIC18F1320 Downloading RS... RS download complete Programming download... Downloading AP... AP download complete Programming download... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.45.41 Firmware type..............PIC18F Target voltage detected Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device. |
因此,我再次使用软件/下载PACIT操作系统将PK3返回到软件PK3,并且我寻找包含从微芯片“PK3OSV02005 .HEX”下载的PACKIT 3的文件中包含的十六进制……PK3继续连接到PC,但不识别18F。并且不记录它被识别为16F690和12F675…
以上来自于百度翻译 以下为原文 So I returned the pk3 to the softwere pk3 again, using tools / download PICkit operating system, and I look for the hex contained in the files of installation of the pickit 3 that I download from microchip "PK3OSV020005.hex" ... Pk3 continues to connect well to the pc but does not recognize the 18f and does not record the ones it recognizes as 16f690 and 12f675.... |
你认为这适用于MEHTTP://博客。
以上来自于百度翻译 以下为原文 You think this works for me http://blog.mbedded.ninja...-to-unbrick-a-pickit-3 |
最后一组来自PICTIT3的消息(在POST 10中)表明您正在与PICTIT3 OK对话,但是它与MCU之间的连接不正确。检查PGC/PGD/MCLR线路(它们可以根据MCU有不同的名称)线路被正确连接,并且没有额外的连接。NEUE设备连接(例如电容器)。它可以在您的板上看到VDD和VSS。OK。苏珊。
以上来自于百度翻译 以下为原文 The last set of messages from the PicKit3 (in post #10) indicate that you are talking to the PicKit3 OK but that the connections between it and the MCU are not right. Check the PGC/PGD/MCLR lines (they can have different names depending on the MCU) lines are properly connected and there are no extraneous devices connected (e.g. capacitors). It can see the Vdd and Vss on your board OK. Susan |
您的PICTIT3不是砖砌体。它对您没有帮助。您有可能损坏PICTIT3。如果您已经验证了所有外部连接,以及电源。
以上来自于百度翻译 以下为原文 Your PICKit3 is NOT Bricked. It will not help you. There is a possibility that you PICKit3 is damaged. If you have verified all the external connections,and the Power. |
连接是好的…我在PCB上尝试过,我经常录制,我在Poto板上做了测试,有几种类型的PIC…18F不识别它们,16F不记录它们。
以上来自于百度翻译 以下为原文 The connections are ok ... I tried it in pcb that I have usually recorded and I have done tests in the proto board with several types of pic ... the 18f does not recognize them and the 16f does not record them |
通过这里的自检程序:HTTP://www. McCHIP.COM/CISAR/DEFUCT.ASPX?类型=PICIT3,如果它是真正的PICTIT3,如果它被损坏,Microchip可能会免费更换它。
以上来自于百度翻译 以下为原文 Work through the self test procedure here: http://www.microchip.com/cisar/Default.aspx?type=pickit3 If it is a genuine PICkit3, and if it is damaged, Microchip will probably replace it for free. |
很抱歉,除非你从美国的Microchip直接购买你的PICTIT3,而你在美国使用它,你就不可能有任何保证。Microchip似乎永远愿意取代ICD3、Realice或PM3设备程序员。对于PICkits,初学者工具包,演示板等微芯片似乎没有慷慨的免费更换。如果你的皮卡3坏了,买一个新的,一个真正的,而不是一个克隆,那么至少你可以得到一个准确的示意图,并有机会自己修理它下一次你抽烟。
以上来自于百度翻译 以下为原文 Sorry to say that unless you purchased your PICKit3 directly from Microchip in the USA and you are using it in the USA it's not likely you have any warranty. Microchip seems willing to replace ICD3, RealICE or PM3 device programmers forever. For PICkits, Starter kits, demo boards etc. Microchip does not seem to be so generous with free replacements. If your PICkit3 is broken buy a new one, a REAL one not a clone, then at least you can get an accurate schematic and have a chance at fixing it yourself the next time you smoke it. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 09:16 , Processed in 1.513334 second(s), Total 104, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2008
