电子发烧友论坛|
如何使用39VF1602闪存作为配置设备处理Impact a Vitrex 5?
Impact无法识别闪存中的设备ID,并通过编程停止。 谢谢,汉斯 以上来自于谷歌翻译 以下为原文 How do I handle in Impact a Vitrex 5 with a 39VF1602 Flash as configuration device ? Impact does not recognize the device id from the flash and stops with programming. Thanks , Hans |
5个回答
嗨汉斯,
DId上面的解决方案帮助。 如果它有所帮助,请将其标记为答案。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Hans, DId the above solution help. In case it helped, kindly mark it as an answer. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
嗨,
您可以跳过evnironment变量中的IDCODE检查。 使用IMPACT工具,不会检查FLASH的ID代码,因此您可以编程FLASH,从而编程FPGA。 请在下面找到用于跳过ID代码的环境变量。 “XIL_IMPACT_SKIPIDCODECHECK = 1” 在将mcs文件分配给spi flash期间,您可以选择其他制造商闪存(具有相同的大小)。 您可以在下面更改环境变量。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, You can skip the IDCODE check in the evnironment variables. With this the IMPACT tool, will not check the ID code for the FLASH and hence you can program the FLASH and hence the FPGA. Please find below the environment variable for skipping the ID code. "XIL_IMPACT_SKIPIDCODECHECK=1" You can select the other manufacturer flash(with the same size) during assigning of the mcs file to the spi flash. Below is where you can change the environment variable. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨汉斯,
DId上面的解决方案帮助。 如果它有所帮助,请将其标记为答案。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi Hans, DId the above solution help. In case it helped, kindly mark it as an answer. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
很高兴听到!!
谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Nice to hear that!! Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:56 , Processed in 0.883466 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3631
