用户手册提到使用一个88%反射率目标和17%反射率目标进行校准。我不知道这些反射率值是什么材料。我应该用什么来校准?我在哪里可以得到它们?
以上来自于谷歌翻译 以下为原文 The user manual mentions using one 88% reflectance target and 17% reflectance target for calibration. I don't know what material has those reflectance values. What exactly should I use for calibration and where can I get those? |
4个回答
你好,
看看这个讲座介绍: https://www.cs.cmu.edu/afs/cs/academic/class/15462-f09/www/lec/lec8.pdf 此外,维基百科提供了很好的解释: https://en.wikipedia.org/wiki/Reflectance 但是,我无法找到一些在线值得信赖的各种材料反射率数据库。 大卫 以上来自于谷歌翻译 以下为原文 Hello, Have a look at this lecture presentation: https://www.cs.cmu.edu/afs/cs/academic/class/15462-f09/www/lec/lec8.pdf Also, Wikipedia offers quite good explanation: https://en.wikipedia.org/wiki/Reflectance However, I wasn't able to find some online trustworthy database of reflectance of various materials. David |
谢谢大卫!您发布的两个链接解释了反射率非常好。听起来白色目标可能是不透明的,表面光滑。黑暗的目标可能是更粗糙的东西?
我在Google上找到了这张图表。我不知道这是多么值得信赖,但我认为这很有趣。 以上来自于谷歌翻译 以下为原文 Thanks David! The two links you posted explained what reflectance is pretty well. It sounds like the white target is probably something opaque and with a smooth surface finish. And the dark target is probably something with a rougher finish? I found this chart on Google. I don't know how trustworthy this is but I thought it was interesting enough. |
我在VL53L0X数据表中找到了这句话(在'Performance' - >'Measurement Conditions'下):
反射目标是标准目标(灰色17%N4.74和白色88%N9.5孟塞尔图表)。 因此,目标似乎是Munsell色卡。现在问题变成了如何获得那些色卡......在线快速搜索只显示小口袋大小的色卡,这可能不够大...... 以上来自于谷歌翻译 以下为原文 I've found this sentence from the VL53L0X datasheet (under 'Performance' -> 'Measurement Conditions'): Reflectance targets are standard ones (Grey 17% N4.74 and White 88% N9.5 Munsell charts). So it seems like the targets are Munsell color cards. Now the problem becomes how to get those color cards... A quick search online only reveals small pocket sized color cards, which is probably not big enough... |
它叫做Munsell Color Paper
X-rite公司 4300 44th S.E. 大急流城,Mi 49512 电话877-888-1720 东西很贵。像每张26美元贵。 我们在测试中使用5%,17%,42%和88%的反射率。每张一种颜色。 MUNSEL NOTATION N2.75 / 以上来自于谷歌翻译 以下为原文 It’s called Munsell Color Paper X-rite Inc 4300 44th street S.E. Grand Rapids, Mi 49512 Tel 877-888-1720 The stuff is expensive. Like $26 per sheet expensive. We use 5%, 17%, 42% and 88% reflectances in our testing. One color per sheet. MUNSEL NOTATION N2.75/ |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1539 浏览 1 评论
2217 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1517 浏览 1 评论
2871 浏览 6 评论
5351 浏览 21 评论
382浏览 4评论
614浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
294浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
704浏览 3评论
582浏览 3评论
GMT+8, 2024-5-5 19:55 , Processed in 0.811081 second(s), Total 82, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
