电子发烧友论坛|
你好
我在STM32F107xC上运行电机控制库3.4.1。 它不断崩溃到“硬件故障”异常中。 我已对IAR项目构建进行了必要的调整,并且必须调整库中的某些定义以将构建配置扩展到STM32F10X_HD之后。 是否有一些基本原因导致库未记录在F107设备上运行? 或者,什么可能抛出硬件异常? 谢谢 卢克 #CL-设备电机控制库 以上来自于谷歌翻译 以下为原文 Hi I am running the Motor Control library 3.4.1 on the STM32F107xC. It keeps crashing into the 'Hardware Fault' exception. I have made the necessary adjustments to the IAR project build, and had to adjust some defines in the library to extend the build configuration past the STM32F10X_HD. Is there some basal reason that the library is not documented to run on the F107 device? Or, what could be throwing the hardware exception? Thanks Luke #cl-device-motor-control-library |
4个回答
为了更清楚地了解上述问题,我在STM32F107xC连接线设备上的MC实现适用于:
- 单电机 - 编码器或3x霍尔效应。 在执行调用期间,实现崩溃: MCboot(OMCI,OMCT); // |
在调整CL设备的库配置时,我忽略了调整电路板上特定晶体的启动代码。现在我已经在我的CL设备上调整了8MHz晶振的时钟配置代码 - 提供的库代码假定为25MHz晶体 - 崩溃已经停止。
现在我已经掌握了MCWB软件。 正在解决为什么当电机现在没有运行时报告“过流”的原因。我与MB459套件的增益电路略有不同,但在MCWB设置中进行了相应的调整。 虽然我不是100%肯定它正在处理运算放大器模拟处理。发送到源代码的#defines虽然包含有关增益的信息,但似乎不包含有关“零”级别的信息。 #define RSHUNT 0.220 #define AMPLIFICATION_GAIN 2.12 ......似乎是唯一进入代码的#defines;因此,当我知道没有电机电流流动时(在MCBoot()时间?),我假设磁带库通过自校准自动神奇地调整电流“零”(单端运算放大器前端偏置) - 是这个案子呢? 有任何想法吗? 以上来自于谷歌翻译 以下为原文 In adjusting the library configuration for the CL device I neglected to adjust the startup code for the specific crystal on my board. Now that I've adjusted the clock config code for my 8MHz crystal on my CL device - the provided library code assumes a 25MHz crystal - the crashing has stopped. Now I have comms up with the MCWB software. Just working through why it's reporting 'overcurrent' when the motor is not running now. I have slightly different gain circuits from the MB459 kit, but have adjusted accordingly in the MCWB setup. Although I'm not 100% sure it's handling the op-amp analog processing right. The #defines which are sent through into the source code, while including information about the gain, doesn't seem to include information about the 'zero' level. #define RSHUNT 0.220 #define AMPLIFICATION_GAIN 2.12 ... seem to be the only #defines going into to code; so I assume that the library auto-magically adjusts for current 'zero' (the single-ended op-amp front-end biasing) by self calibrating when it knows there is no motor current flowing (at MCBoot() time?) - is this the case? Any ideas? |
看起来该库确实执行了它自己的零电流校准,这非常好 - 因此MCWB正在将足够的模拟电流信号处理传递给库。
过电流。我很困惑。似乎需要一些术语的一致性,以及增加术语的相关性。 显然,“紧急停止”相当于“制动”输入相当于“过电流”。 但我不确定MCWB对此的控制在哪里。 “Power Stage - Over-current protection”下有可疑设置,然后是“过流保护禁用网络”。 如果这是真的,这是==&gt;同名的4个名字!!!! &LT; === 然后,再次,这次只是为了好玩,在“控制阶段”和过流保护拓扑下,可以选择“外部保护”或“无保护”。 因此我选择了“无保护”,现在过流警告已经消失,因为我的应用程序使用PE15(不能在MCWB中重新分配)用于其他目的。 以上来自于谷歌翻译 以下为原文 It seems that the library does perform it's own zero-current calibration, which is excellent - so the MCWB is passing enough analog current signal processing to the library. Over-current. I am confused on this. It seems that some consistency in nomenclature is required, along with increased pertinence of terms. Apparently 'Emergency Stop' is equivalent to 'Brake' input is equivalent to 'over current.' But I'm not sure where the MCWB control for this is. There are suspicious-looking settings under 'Power Stage - Over-current protection,' and then 'Over-current protection disabling network.' Which, if this is true, this is ==> 4 names for the same thing !!!! <=== Then, again, just for fun this time, under 'Control Stage' and Over-Current Protection Topology, 'External Protection' or 'No protection' can be selected. So I selected 'No protection' and now the over-current warning is gone, since my application uses PE15 (not re-assignable in the MCWB) for another purpose. |
Ciao Luke,
是的,lib在每次重启电机时执行偏移校准, 是的,命名法中有一点冗余:过电流,制动输入和紧急停止是等效的。 “过电流保护禁用网络”具有不同的含义,是一种允许暂时禁用过电流保护的网络,可以使用“额外”电流。 如果您没有可用的紧急输入/过电流/制动输入/ PE15引脚,则唯一的想法就是禁用保护...然后交叉手指。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Luke, yes, the lib performs the offset calibration at each restart of the motor, and yes, there is a little bit redundancy in the nomenclature: Over current, Brake Input and Emergency stop are equivalent. The 'Over-current protection disabling network' has different meaning and is a network to allows to disable temporary the over current protection to have the possibility to work with an ''extra'' current. If you don't have the Emergency Input/Over current/Brake input/PE15 pin available the only think is to disable the protection as you did... and then cross the finger. Ciao Gigi |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 22:09 , Processed in 0.541883 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3411
