你好
我正在使用MGT(GTX更具体)来实现两个FPGA之间的通信。 我们可以选择不同的协议,如AURORA。 我们还可以通过以太网等与网络进行通信。还有其他协议,如PCI,...... 这些协议中的每一个都需要用于帧发送/接收的SF(帧开始),IDLE和EF(帧结束)序列,并且每个都具有其自己的序列。 我如何知道这些序列,以便我可以设计我的包装器来使用我的自定义逻辑? 我为Aurora研究了pg074,但我找不到我需要的东西。 我在使用以太网时遇到了同样的问题,不过我很快就回顾了IEEE802.3。 PCI和其他协议也存在类似的问题。 谢谢 以上来自于谷歌翻译 以下为原文 Hi I'm using MGTs (GTX to be more specific) for communication between two FPGAs. We can select different protocols, like AURORA. We can also communicate to a network via Ethernet, etc. There are other protocols such as PCI, ... Each of these protocols require SF(Start of Frame), IDLE, and EF(End of Frame) sequences for frame transmission/reception and each has its own sequences. How can I know these sequences, so that I can design my wrapper to work with my custom logic? I have studied pg074 for Aurora, but I could not find what I needed. I have the same problem for working with Ethernet, though I shortly reviewed IEEE802.3. Similar problem also exists for PCI and other protocols. Thanks |
3个回答
这些细节将在各个协议的规范中找到。
如果您选择实现协议的IP内核(而不是MGT向导包装器),那么这些将作为IP内核的一部分包含在内,但如果您从头开始,那么您需要阅读协议规范以完全理解整个集合 实施协议的要求。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The details of these will be found in the specification for the individual protocols. If you select an IP core (not a MGT Wizard wrapper) that implements the protocol then these will be included as part of the IP core, but if you are starting from scratch then you need to read the protocol specification to fully understand the entire set of requirements to implement the protocol. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
嗨,
您的查询是否已回答? 如果是,那么请标记答案! 如上所述,您需要为特定IP生成核心以检查这些协议的详细信息。 如果Coregen支持协议,IP核应该为您完成所有这些工作。 如果你找不到你想要的东西,请告诉我。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Is your query answered? If yes, then please mark the answer!. As discussed, you need to generate the core for the specific IP to check the details of these protocols. The IP core should be doing all these for you in case that protocol is supported in Coregen. Let me know if you cannot find what you are looking for. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
我知道协议有自己的框架字符,但我需要物理层字符。
我在这篇文章中更详细地解释了我的问题: http://forums.xilinx.com/t5/General-Technical-Discussion/Feeding-data-into-GTX/td-p/383665 你可以阅读那篇文章并回答我的问题吗? 谢谢 以上来自于谷歌翻译 以下为原文 I know protocols have their own framing characters, but I need physical layer characters. I explained my question in more detail in this post: http://forums.xilinx.com/t5/General-Technical-Discussion/Feeding-data-into-GTX/td-p/383665 Could you please read that post and answer my question? Thanks |
只有小组成员才能发言,加入小组>>
2325 浏览 7 评论
2739 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2223 浏览 9 评论
3302 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2372 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
664浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
470浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
238浏览 1评论
677浏览 0评论
1870浏览 0评论
GMT+8, 2024-10-6 22:22 , Processed in 1.255292 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
