嗨,
我有我的zynq zc702 ..现在我需要在一些相同的sapce中对它进行分区,以便我的每个VHDL程序可以单独映射到这个空间? 可以提前计划吗? 可以提供任何教程吗? 我需要PR工具吗? 我只是初学者 以上来自于谷歌翻译 以下为原文 Hi, I have my zynq zc702..now I need to partition it in some equal sapce, so that my each VHDL program can be mapped separately in to this space? can plan ahead do this? can any tutorial be provided? do I need PR tool for this? I am just beginer |
8个回答
检查这个http://forums.xilinx.com/t5/Design-Planning/How-to-get-a-Partial-Reconfiguration-license-feature/td-p/111920
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Check this http://forums.xilinx.com/t5/Design-Planning/How-to-get-a-Partial-Reconfiguration-license-feature/td-p/111920 Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
检查分层设计方法指南以获取一些建议http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/Hierarchical_Design_Methodology_Guide.pdf
-------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Check Hierarchical design methodology guide for some suggestions http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/Hierarchical_Design_Methodology_Guide.pdf------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
嗨,
以下是部分重新配置教程的链接:http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/PlanAhead_Tutorial_Partial_Reconfiguration.pdf 此外,您还需要具有部分重新配置的单独许可证。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Here is link to Partial reconfiguration tutorial http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/PlanAhead_Tutorial_Partial_Reconfiguration.pdf Also you need to have seperate license for partial reconfiguration. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
目前我没有PR工具......所以可以使用14.4之前的计划吗?
因此可以在该分区中进行适当的分区和设计映射 以上来自于谷歌翻译 以下为原文 presently I donthave PR tool...so can it be done using plan ahead 14.4? so proper partition and design mapping in that partition can be done |
嗨,planahead支持分区,但要在planahead中启用此功能,您需要有单独的PR许可证。谢谢,Deepika。
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Partitions are supported in planahead but to enable this feature in planaahead you need to have seperate PR license. Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
我可以获得PR的评估许可证吗? xilinx是否提供此类服务? 以上来自于谷歌翻译 以下为原文 Hi, Can I get evaluation license for PR? Does xilinx provides such? |
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Check this http://forums.xilinx.com/t5/Design-Planning/How-to-get-a-Partial-Reconfiguration-license-feature/td-p/111920 Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
如果您对此帖有任何疑问,请告诉我们? 如果您找到问题的解决方案,请标记答案,以便对其他论坛用户有所帮助。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Let us know if you have any more queries on this post? Please Mark the answer in case you found the solution to your question so that it can be helpful for other forum users. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
2179 浏览 7 评论
2617 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2212 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
451浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
516浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-14 14:00 , Processed in 1.284864 second(s), Total 92, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
