电子发烧友论坛|
你好,我做了一个板只是在开发套件3686示意图。不同的是我的设计只有一个闪存芯片和3686有8。问题是,使用nx2lp程序工具配置我的板时,第一阶段:规划似乎已经过去了,但第二阶段,有错误:FAT32格式化失败。我想知道是什么引起了这个问题。希望你们能帮助我!顺便说一句,我的USB芯片cy7c68023,FLSH芯片是三星k9f1g08uoa
以上来自于百度翻译 以下为原文 Hi there, I 've made a board just following the schematic in development kit 3686. The difference is My design had only one Flash chip and the 3686 had 8. The problem is that when using the Nx2lp program tools configuring my board, the first stage: programming seems had passed, but the second stage, there was error: Fat32 formatting failed. i was wondering what caused this problem. May you guys can help me! btw, My u*** chip is cy7c68023, flsh chip be samsung k9f1g08UOA |
7个回答
当使用MFGooCAD编程NAND Flash时,MFGooT接口的界面底部会有状态文本。首先,状态文本连接到XXXX,点击界面上的程序按钮,状态文本将是:编程……,这是我所声称的第一阶段,过一会,状态文本将是:格式化失败!这是第二阶段。如果我解释得很好?
以上来自于百度翻译 以下为原文 when using Mfgtool to program the Nand flash, there will be status text at bottom of the interface of the mfgtool's interface. First the status text is Connect to XXXX, the click the program button on the interface, the status text will be: programming..., which is the first stage i claimed, after a short while the status text will be :Formatting failed! , which is the second stage. if i explained it well? |
这意味着它不能用数据写一个配置块。连接到XXXX意味着它能够与NAND对话。你是否被要求输入参数,如块大小、页面数量等,还是直接加上名字????
以上来自于百度翻译 以下为原文 It means it is not able to write a configuration block with the data.... connect to XXXX means it is able to talk to the NAND i.e identify manufacturer id and stuff... were you asked to enter the parameters i.e block size, number of page etc etc or did it just came up with the name directly??? |
谢谢。当然,它的名字和名字信息是正确的。那么,你的意思是它不能把配置信息写入右边的块?
以上来自于百度翻译 以下为原文 Thx a lot. Sure, it came up with the name directly and the name info is correct. So you meant that it could not write configuration info to the right block? |
这是你第一次编程NAND还是过去使用过的NAND…如果在使用Ctrl+W(擦除NAND)之前使用它,然后尝试编程通常会有帮助。兼容性列表中的这种类型的NAND是K9F1G08UOAYCB0,检查您的是否是相同的,这可能是由于编程工具用于编程NAND的参数而导致的。
以上来自于百度翻译 以下为原文 Is it the first time you are programming that NAND or was it used in the past.... If it was used before using Ctrl+W (erases the NAND) and then trying to program helps often.... the NAND of this type in the compatibility list is k9f1g08UOA-YCB0 check whether yours is the same else this might be a screw up due to the parameters used by the programming utility to program the NAND.... |
我尝试过“CTRL+W”方法,但也做不到。也许在兼容列表中使用Flash芯片可以解决这个问题,我会试试看。
以上来自于百度翻译 以下为原文 I've tried the "Ctrl+w" method, but it also couldn't make it. Maybe using a flash chip in the compatible list may resolve the problem, I'll try it. |
问题解决了:我在兼容的列表中改变了一个芯片,然后它可以被编程和格式化。但是还有一个问题,如果我使用一个不兼容的芯片,我该怎么做才能使它运转起来?我需要更改固件并创建新的.NX2文件吗?
以上来自于百度翻译 以下为原文 The problem is resolved: i changed a chip in the compatible list, then it can be programmed and formatted. but there is another question, If i use a chip that's not in the compatible list, what should i do to make it goes around? shall i change the firmware and create new .nx2 file? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 18:48 , Processed in 0.945873 second(s), Total 86, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4103
