电子发烧友论坛|
你好
我使用的是STM8AL318AT。什么是正确的外设寄存器包括要使用的文件?标准peripgeral库中的stm8s.h includ文件不支持任何AL设备。我可以使用stm8l15x.h文件并取消注释HD设备吗? 问候 /约翰 以上来自于谷歌翻译 以下为原文 Hi I am using a STM8AL318AT. What is the correct peripheral resisters include file to use? The stm8s.h includ file from the standard peripgeral library does not support any AL device. Can I use the stm8l15x.h file and uncomment the HD device? Regards /Johan |
5个回答
你好约翰
我把你的问题转移到了 https://community.st.com/community/automotive-mcus-community/spc5-automotive-mcus 论坛,有人应该能够帮助你。谢谢 奥利 以上来自于谷歌翻译 以下为原文 Hello Johan I have moved your question to the https://community.st.com/community/automotive-mcus-community/spc5-automotive-mcus forum where someone should be able to assist you.Thanks Oli |
你好约翰,
即使它可能是汽车MCU,STM8A也相对于臂芯而非PPC(SPC5系列) 我已将您的问题提交给STM8 Part 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Johan , Even if it could be an automotive MCUs, STM8A is relative to the arm core not PPC (SPC5 Family) i have put your question in STM8 Part Best regards Erwan |
您好,让我带来一点精度。 STM8不基于ARM内核。这是ST开发的专有核心。如果没有正确描述STMAL318AT(我会检查并要求更正的东西),STM8L15x会这样做。
事实上,我们已经扩展了标准STM8L的认证和故障覆盖范围,以使设备与AEC-Q100保持一致。 帕特里斯 以上来自于谷歌翻译 以下为原文 Hello, let me bring a little precision here. The STM8 is not based on ARM core. This is a proprietary core developed by ST. If the STMAL318AT is not described properly (Something I will check and ask for correction), the STM8L15x will do. In fact we have extended the qualification and fault coverage of the standard STM8L in order to get the devices aligned with the AEC-Q100. Patrice |
要回答原始问题,请使用正确的库包
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8016.html 头文件是 并且在项目中定义的正确宏是: 马克斯 以上来自于谷歌翻译 以下为原文 To answer to the original question, the correct library package is http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8016.html The header file is and the correct macro to define in the project is: Max |
好的,谢谢Max
听起来很明显也很正确!我想我下载一些LIN(STSW-STM8073 / 74)示例时得到的stm8l15x.h文件没有这个宏,它是一个旧版本。 问候 /约翰 以上来自于谷歌翻译 以下为原文 Ok, thanks Max It sounds obvious and correct! I guess the stm8l15x.h file I got when I downloaded some LIN (STSW-STM8073/74) example did not have this macro, it was an older version. Regards /Johan |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 10:09 , Processed in 0.792423 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2160
