电子发烧友论坛|
你好!我正在努力让我的FX2LP工作(68014A)。我设计并制造了一个简单的样板。如果我插入它,它列举为FX2LP,EEPROM失踪。(有一个空EEPROM)到目前为止,很好。接下来,我尝试加载一些演示应用程序中找到(CY3684EZUSbfx2LppDealEngestKITY15.exe)。他们都没有工作(试过BulkRoub和其他一些)。不太好。Windows错误消息类似于:设备无法被识别。VID/PID为0000/0000。假设0000是不可识别设备的默认值。甚至不要求司机。然后,我安装了.NET工具(SuieSubByNET2O00Sy.UbbDealthMyTooSoSo.FuxVisualStudioOx05Syand and No.2N02O03Y0A14.MSI)。我下载了CyScript HEX。Windows很好地识别了它(正确的VID/PID)。但是在浏览了驱动程序之后,我得到了一个错误10:设备无法启动。不好的。我尝试的下一个示例是:Apple PosixNo.SooCytoCudio.BuxPoopEdEdEntRealType,FX2S.13Zip。下载HEX文件后,它工作了。这是一个BulkLoad的例子,再次!我甚至成功地创建了一个修改的.INF驱动程序文件。它与CyPress USB控制台很好地工作。但是SUIT.NET组件不将设备识别为USB设备(UbDeVieleListor没有找到它),尽管它也找到了我的外部硬盘和键盘。我还发现了另一个例子:CySalthyOxLasiGuang-OrthuSubSuffiSuthSouthySuxand BulkyTrims19.Zip。CyStream又来了。我成功下载了IIC文件到EEPROM,Windows枚举了设备作为CY流,但是驱动程序再次失败:错误10,设备无法启动。我在这里有点不舒服。我想要的是一个工作样本,BulkRoobe将是伟大的,和一个工作.NET接口启动。有人能帮忙吗?我做错什么了?谢谢!千伏
以上来自于百度翻译 以下为原文 Hi! I am trying to get my fx2lp working (68014a). I have designed and manufactured a simple sample board. If I plug it in, it enumerates as fx2lp, eeprom missing. (There is an empty eeprom) So far, so good. Next I tried to load some demo apps found in (cy3684_ez_u***_fx2lp_development_kit_15.exe). None of them worked (tried bulkloop, and some others). Not so good. The Windows error message is something like: The device cannot be recognised. VID/PID is 0000/0000. I assume 0000 is the default value for unrecognizable devices. Not even asking for drivers. Then I installed the .NET tools (suiteu***_net_2_0___u***_development_tools_for_visual_studio_2005_and__net_2_0_3_0_14.msi). I downloaded the CYStream hex. Windows recognised it well (correct VID/PID). But after browsing the driver I got an error no. 10: The device cannot be started. Not good. The next sample I tried was: application_note_source_code___bus_powered_enumeration_with_fx2_13.zip. After downloading the hex file, it worked. It is a Bulkloop example, again! I even managed to create a modified .inf driver file. It works well with the Cypress USB console. But the Suite.NET component does not recognize the device as an USB device (USBDeviceList does not find it) although it finds my external HDDs and my keyboard also. I also found an other example: cystream___streaming_over_u***_with_isochronous_and_bulk_transfers_19.zip. CyStream again. I downloaded the iic file successfully to the EEPROM, Windows enumerated the device as CY-Stream, but the driver failed again: error 10, the device cannot start. I am kinda stucked here. All I want is a working sample, bulkloop would be great, and a working .NET interface for start. Can anyone help? What did I wrong? Thanks! KV |
3个回答
HI解调,有PCB布局建议和示意图可用。看看他们。这0000 VID/PID主要是由于示意图的问题。无法识别您的设备的.NET接口是由于注册表中缺少DRIVURGUID值。在INF文件中取消CysU.GuID和DeReGueD.AddiRg部分的注释。这应该解决.NET接口问题。问候,Aasi
以上来自于百度翻译 以下为原文 Hi demodl, There is pcb layout recommendations and schematics available. take a look into them. This 0000 Vid/pid is mostly a problem due to the schematics. The .net interface not recognising your device is due to the absence of driverguid value in the registry. In the inf file uncomment the cyus.guid and Driverguid.addreg section. this should resolve the .net interface problem. Regards, Aasi |
我得到同样的问题,但从FixEV板从赛普拉斯。如果我用命令行{HEX2BIX-F 0xC2—I编程.IIC程序.HEX}转换程序.HEX文件(我的小程序,如果EZ-USB控制面板/下载程序工作得很好),通过EZ-USB控制面板/EEPROM下载它,在重置设备后得到相同的错误。我做错什么了?谢谢!问候,简
以上来自于百度翻译 以下为原文 I get the same problem, but with a FX2 Ev Board from Cypress. If I convert the programm.hex file (my little program, working well if programmed by EZ-USB Control Panel / Download...) by commando {hex2bix -F 0xC2 - I programm.iic programm.hex} to a .iic file and download it by EZ-USB Control Panel / EEPROM I get the same error after resetting the device. What do I wrong? Thanks! Regards, Jan |
即使你的固件是几个字节的外部存储器就必须使用-e选项而不是我的选择…或者你的固件完全在内存中?????
以上来自于百度翻译 以下为原文 even if a few bytes of your firmware lies in external memory then you'll have to use -e option instead of -i option... or is your firmware fully in internal memory???? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:16 , Processed in 0.748530 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1807
