问候,
我正在使用Xilinx Spartan 3E入门套件。 我想将配置位文件下载到板载SPI存储器中。 我阅读了一个关于利用picoblaze以及终端程序(HyperTerminal)的pdf文件,通过RS 232电缆与内存建立通信。 虽然我一直试图解决这个问题,但我总是失败。 所以这是我的问题: 1)从可用的硬件开始:是否可以通过RS 232到USB电缆对SPI进行编程,还是应该更改电缆类型? 2)如果可以使用上面提到的RS 232电缆,它是否仅限于picoblaze,还是可以使用iMPACT对SPI闪存进行编程? 3)如果iMPACT可以对SPI进行编程,在这种情况下,当我将其插入电路板时,如何检测电缆的存在?4)应该注意的是,我用picoblaze方法尝试了很多次( 在第1点中提到,但没有用。 电缆未被检测到。 非常感谢任何帮助和文档名称。 此致,Mahmoud 以上来自于谷歌翻译 以下为原文 Greetings, I am using a Xilinx Spartan 3E starter kit. I want to download a configuration bit file to the SPI memory on board. I read a pdf file about making use of the picoblaze as well as a terminal program (HyperTerminal) to establish communication with the memory through an RS 232 cable. Although I have continuously tried to solve this issue, I always failed. So here are my questions: 1) Starting by the available hardware: Is it possible to program the SPI via an RS 232 to USB cable, or should I change the cable type? 2) If the RS 232 cable mentioned above could be used, is it limited only to the picoblaze, or can I program the SPI flash using iMPACT? 3) If iMPACT could program the SPI, in this case, how do I make it detect the presence of the cable when I plug it into the board? 4) It should be noted that I tried a lot of times with the picoblaze method (mentioned in point 1), but no use. The cable is not being detected. Any help and document names is very much appreciated. Regards, Mahmoud |
1个回答
阅读“Spartan-3代配置用户指南”。
----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 Read the Spartan-3 Generation Configuration User Guide. ----------------------------Yes, I do this for a living. |
只有小组成员才能发言,加入小组>>
2294 浏览 7 评论
2704 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2188 浏览 9 评论
3269 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2333 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
604浏览 1评论
1664浏览 1评论
163浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2322浏览 0评论
634浏览 0评论
GMT+8, 2024-9-5 12:16 , Processed in 1.333684 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
