电子发烧友论坛|
嗨,在我们公司,我们拥有DSO-X-3034A和MSO9254A。
我们想知道是否可以设置其中一个示波器,以便在发生触发时自动将屏幕截图保存到磁盘(或USB)(“单个”或“正常”触发模式)。 在观察和调试非常罕见的现象时,这将非常有用,例如每天一次或两次。 例如,我们曾经有一个随机丢失锁定的PLL,但非常罕见且持续时间很短。 然后我们可以触发锁定信号,并且与自动屏幕截图一起,我们可以在锁定丢失的时候观察到一些输入和输出信号。 我们在文档和论坛中没有找到关于这样一个主题的任何内容,任何帮助都表示赞赏。 谢谢你,最诚挚的问候,哈拉尔德。 以上来自于谷歌翻译 以下为原文 Hi, at our company, we own both a DSO-X-3034A and a MSO9254A. We wonder if it is possible to set up one of these scopes to automatically save a screenshot to the disk (or USB) when a trigger occurs ("Single" or "Normal" trigger mode). This would be very helpful when observing and debugging phenomenas, which occur very rare, for example once or twice a day. For example, we once had a PLL, which randomly lost its lock, but very rare and only for a short duration. We could have then triggered on the lock signal and together with the automatic screenshot we could have observed some input- and output-signals at exactly the time when the lock was lost. We didn't find anything about such a topic in the documentation nor in the forum, any help is appreciated. Thank you, best regards, Harald. |
4个回答
在2000/3000 / 4000X上,没有没有编程。
在9000A和其他Infiniium上,查看触发操作。 另见:BENCHVUE! 自由。 简单。 主页& 下载:www.agilent.com/find/benchvue mobile for IOS& Android:www.agilent.com/find/benchvuemobile教程:www.agilent.com/find/benchvuevideos免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 on 2000/3000/4000X, no not w/o programming. on 9000A and other Infiniiums, check out Action on Trigger. see also: BENCHVUE! FREE. EASY. Homepage & download: www.agilent.com/find/benchvue mobile for IOS & Android: www.agilent.com/find/benchvuemobile tutorials: www.agilent.com/find/benchvuevideos Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
您好ksmith,谢谢您的快速回复,我将使用9000A检查并尝试使用benchvue软件!
问候,哈拉尔德 以上来自于谷歌翻译 以下为原文 Hi ksmith, thank you for your quick response, I'm going to check that with the 9000A and try the benchvue software as well! greetings, Harald |
我不确定这是否有效,但您是否尝试过分段内存?
您可以将其设置为触发解锁信号,并且每次发生事件时都会存储它。 然后,您可以滚动浏览已保存的细分,并将事件视为屏幕截图。 杰克威尔科电子。 以上来自于谷歌翻译 以下为原文 I'm not sure if this will work but have you tried the segmented memory? You could set it up to trigger on the unlock signal and every time an event occurs it would be stored. You can then scroll through saved segments and view or save the event as a screen capture. Jack Willco Electronics. |
如果您购买了Mask Test许可证,那么您可以这样做。
为失败案例设置掩码(或者只是设置一个全屏掩码,以便在作用域触发时失败)。 然后,每次发生这种情况时,将示波器设置为USB。 附件是Mask Testing文档的片段:添加了截图 以上来自于谷歌翻译 以下为原文 If you purchase the Mask Test license, you can do just that. Set up a mask for the failure case (or just set up a full-screen mask so that it fails the moment the scope triggers). Then, set the scope to save to USB every time this happens. Attached is the snippet of the Mask Testing documentation: Added screenshot 附件
只有小组成员才能发言,加入小组>>
1846 浏览 0 评论
2740 浏览 1 评论
2641 浏览 1 评论
2451 浏览 5 评论
3461 浏览 3 评论
1849浏览 0评论
422浏览 0评论
/9
GMT+8, 2025-12-3 19:12 , Processed in 0.938905 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
360
