我有ML505评估板,我想尝试将LVDS IO模块中的比较器用作1位ADC。
例如,我将一个0 V - 1.5 V的模拟输入连接到SMA J10(SMA_DIFF_CLK_IN_P)和一个参考电压(可能是0.75 V)连接到SMA J11(SMA_DIFF_CLK_IN_N)。 参考电压可以从外部提供,或者我可以使用FPGA的单端输出并驱动RC电路以动态控制参考电压。 从表9中的ds202.pdf,LVDS_25的差分输入电压为100 mV至600 mV。 对于上面的例子,差分电压为750 mV,共模电压也会变化。 这会工作吗? 谢谢。 以上来自于谷歌翻译 以下为原文 I have the ML505 eval board and I want to try to use the comparator in the LVDS IO block as a 1-bit ADC. For example, I'll connect an analog input of 0 V - 1.5 V to SMA J10 (SMA_DIFF_CLK_IN_P) and a reference voltage (maybe 0.75 V) to SMA J11 (SMA_DIFF_CLK_IN_N). The reference voltage could be supplied externally or I could use a single-ended output from the FPGA and drive an RC circuit in order to control the reference dynamically. From Table 9 from ds202.pdf, the differential input voltage for LVDS_25 is from 100 mV to 600 mV. For the above example, the differential voltage would be 750 mV and the common-mode voltage would vary. Would this even work? Thanks. |
3个回答
有几个例子将差分输入用作一位ADC,然后在FPGA架构中使用delta-sigma调制器和抽取器。
----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 There are several examples out there of using the differential inputs as a one-bit ADC, followed by a delta-sigma modulator and decimator in the FPGA fabric. ----------------------------Yes, I do this for a living. |
表LVDS_25中的数字假设您正在使用高速接口
差分输入。 当满足这些条件时,保证时间满足 数据手册规范。 实际的差分输入具有更宽的共模 和差分范围。 您只需要确保在制作时使用足够的稳定时间 你的测量。 我的猜测是输入仍然会比其他延迟更快 你的测量系统。 请确保保持输入电压范围 接地和Vcco以防止损坏输入,并且不启用差分终端。 - Gabor 以上来自于谷歌翻译 以下为原文 The numbers in the tables for LVDS_25 assume you're using the interface for high-speed differential inputs. When these conditions are met, then the timing is guaranteed to meet the data book specifications. The actual differential inputs have a much wider common-mode and differential range. You just need to be sure to use sufficient settling time when you make your measurements. My guess is that the inputs will still be faster than the other delays in your measurement system. Just be sure that you keep the input voltage range between ground and Vcco to prevent damage to the inputs, and don't enable the differential termination. -- Gabor |
@ bassman59
谢谢。 看起来我想要做的是相当标准的做法。 我想我真的在寻找任何我需要担心的Xilinx /低级特定事物。 @gszakacs 感谢您指出我需要在实例化LVDS缓冲区时禁用差分终端电阻。 看起来我只需要尝试一下,除非我需要考虑其他设置/陷阱。 以上来自于谷歌翻译 以下为原文 @bassman59 Thank you. Looks like what I want to do is fairly standard practice. I guess I'm really looking for any Xilinx/low level specific things I need to worry about. @gszakacs Thank you for pointing out that I need to disable the differential termination resistor when instantiating the LVDS buffer. Looks like I just have to try it out unless there are other settings/gotchas I need to account for. |
只有小组成员才能发言,加入小组>>
2379 浏览 7 评论
2794 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2261 浏览 9 评论
3335 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2427 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
755浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
543浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
364浏览 1评论
1960浏览 0评论
681浏览 0评论
GMT+8, 2024-11-22 02:14 , Processed in 1.507485 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
