电子发烧友论坛|
#include<STM32f10x_lib.h>
#define GPIO_A 0 #define FtiR 1 #define RTIR 2 void LED_Config(){ RCC->APB2ENR|=1<<2; GPIOA->CRL&=0xFFFFFF0F; GPIOA->CRL|=0x00000030; } void KEY_Config(){ RCC->APB2ENR|=1<<4; GPIOC->CRL&=0xFFFFFFF0; GPIOC->CRL|=0x00000008; GPIOC->ODR|=1<<0; } void NVIC_Config(u8 GPIOx,u8 BITx,u8 TRIM){ u8 EXTIADDR; u8 EXTIOFFSET; EXTIADDR=BITx/4; EXTIOFFSET=(BITx%4)*4; RCC->APB2ENR|=0x01;//使能复用IO功能 AFIO->EXTICR[EXTIADDR]&=~(0x000F< EXTI->FTSR|=1< EXTI->RTSR|=1< void MY_NVIC_PriorityGroupConfig(u8 NVIC_Group){ u32 temp,temp1; temp1=(~NVIC_Group)&0x07; temp1<<=8; temp=SCB->AIRCR; temp&=0x0000F8FF; temp|=0x05FA0000; temp|=temp1; SCB->AIRCR=temp; } void MY_NVIC_Init(u8 NVIC_PreemptionPriority,u8 NVIC_SubPriority,u8 NVIC_Channel,u8 NVIC_Group){ u32 temp; u8 IPRADDR=NVIC_Channel/4; u8 IPROFFSET=NVIC_Channel%4; IPROFFSET=IPROFFSET*8+4; MY_NVIC_PriorityGroupConfig(NVIC_Group); temp=NVIC_PreemptionPriority<<(4-NVIC_Group); temp|=NVIC_SubPriority&(0x0F>>NVIC_Group); temp&=0xF; if(NVIC_Channel<32) NVIC->ISER[0]|=1< NVIC->ISER[1]|=1<<(NVIC_Channel-32); NVIC->IPR[IPRADDR]|=temp< void EXTI_Config(){ NVIC_Config(GPIO_A,0,FTIR); MY_NVIC_Init(2,2,EXTI0_IRQChannel,2); } void EXTI0_IRQHandler(){ GPIOA->ODR|=1<<1; } void MY_NVIC_SetVectorTable(u32 NVIC_VectTab, u32 Offset) { //检查参数合法性 // assert_param(IS_NVIC_VECTTAB(NVIC_VectTab)); // assert_param(IS_NVIC_OFFSET(Offset)); SCB->VTOR = NVIC_VectTab|(Offset & (u32)0x1FFFFF80);//设置NVIC的向量表偏移寄存器 //用于标识向量表是在CODE区还是在RAM区 } void MYRCC_DeInit(void) { RCC->APB1RSTR = 0x00000000;//复位结束 RCC->APB2RSTR = 0x00000000; RCC->AHBENR = 0x00000014; //睡眠模式闪存和SRAM时钟使能.其他关闭. RCC->APB2ENR = 0x00000000; //外设时钟关闭. RCC->APB1ENR = 0x00000000; RCC->CR |= 0x00000001; //使能内部高速时钟HSION RCC->CFGR &= 0xF8FF0000; //复位SW[1:0],HPRE[3:0],PPRE1[2:0],PPRE2[2:0],ADCPRE[1:0],MCO[2:0] RCC->CR &= 0xFEF6FFFF; //复位HSEON,CSSON,PLLON RCC->CR &= 0xFFFBFFFF; //复位HSEBYP RCC->CFGR &= 0xFF80FFFF; //复位PLLSRC, PLLXTPRE, PLLMUL[3:0] and USBPRE RCC->CIR = 0x00000000; //关闭所有中断 //配置向量表 #ifdef VECT_TAB_RAM MY_NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else MY_NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif } void Stm32_Clock_Init(u8 PLL) { unsigned char temp=0; MYRCC_DeInit(); //复位并配置向量表 RCC->CR|=0x00010000; //外部高速时钟使能HSEON while(!(RCC->CR>>17));//等待外部时钟就绪 RCC->CFGR=0X00000400; //APB1=DIV2;APB2=DIV1;AHB=DIV1; LL-=2;//抵消2个单位 RCC->CFGR|=PLL<<18; //设置PLL值 2~16 RCC->CFGR|=1<<16; //PLLSRC ON FLASH->ACR|=0x32; //FLASH 2个延时周期 RCC->CR|=0x01000000; //PLLON while(!(RCC->CR>>25));//等待PLL锁定 RCC->CFGR|=0x00000002;//PLL作为系统时钟 while(temp!=0x02) //等待PLL作为系统时钟设置成功 { temp=RCC->CFGR>>2; temp&=0x03; } } int main(){ Stm32_Clock_Init(9); LED_Config(); KEY_Config(); EXTI_Config(); while(1){ // if((GPIOC->IDR&0x00000001)==0x00000000) // GPIOA->ODR|=1<<1; //GPIOA->ODR|=1<<1; } } 不知道哪里配置有问题 |
4个回答
GPIOA->ODR|=1<<1; } 必须在中断函数清被中断标志. 其他的,没细看,你先在我的代码框架下实验一下.在去弄你自己的吧. |
u32 temp,temp1; temp1=(~NVIC_Group)&0x07; temp1<<=8; temp=SCB->AIRCR; temp&=0x0000F8FF; temp|=0x05FA0000; temp|=temp1; SCB->AIRCR=temp; } 我还没弄懂temp|=0x05FA0000;中的0x05FA0000中的高16位是什么意思? 文档没看懂 [31:16] VECTKEY Register key. Writing to this register requires 0x5FA in the VECTKEY field. Otherwise the write value is ignored. [31:16] VECTKEYSTAT Reads as 0xFA05. |
NVIC_Config(GPIO_C,0,FTIR);是我这里搞错了
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 04:48 , Processed in 0.727361 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7529
