我试图连接一个共同从8:1复用到一个2输入1多路复用器。这些只是软件模拟多路复用器。我试图从外部引脚的路线,一个ADC,直接或通过一个ADC tiA之间切换线路。我附上了图解的图片。目前,我有一个缓冲ADC线直接,但我想如果我能摆脱那。在外部引脚和ADC之间是否需要缓冲?
谢谢 采样 146.4 K 以上来自于百度翻译 以下为原文 I am trying to connect a common from an 8 to 1 mux to an input to a 2 to 1 mux. These are just software analog muxes. I am trying to route from external pins to an ADC, switching routes between direct to ADC or through a TIA. I have attached a picture of the schematic. Currently, I have a buffer the direct to ADC line, but I would like to get rid of that if I could. Do I need a buffer between an external pin and ADC? Thanks
6个回答
我想1是用于多路AMUX两VX和IX的你有TIA输入
来自它。 也没有问题,amux1输出坐在由于反馈在TIA的参考? Eg. TIA是一个追随者的VREF,将其输入在2.5? 问候,Dana。 以上来自于百度翻译 以下为原文 I presume AMUX 1 is being used to mux both Vx's and Ix's as you have the TIA input coming from it. Also is there not a problem that AMUX1 output sits at Vref due to fdbk around TIA ? Eg. TIA is a follower to Vref, which puts its inv input at 2.5 ? Regards, Dana. |
一个快速的SPICE仿真证实了早期后(注意运放= 500 mV)—
以上来自于百度翻译 以下为原文 A quick spice simulation to confirm earlier post (note OpAmp out = 500 mV) - |
应该提到这第一次发帖,TIA作为反相运算放大器时,其混合在。外部引脚将被连接到一个电阻传感器再到地面,使节点被拉到VREF绘制电流根据电阻的变化。
以上来自于百度翻译 以下为原文 Should have mentioned this in the first post, the TIA is being used as an inverting op amp when its muxed in. The external pin will be connected to a resistive sensor and then to ground, so that node being pulled to vref is drawing a current according to the change in resistance. |
那么为什么不消除OpAmp和AMUX2,只是添加一个输入到AMUX1的TIA?
或者,如果使用TIA有几个,但不是全部,AMUX1输入,仅仅消除OpAmp,不需要 对于它,因为它有更多的漂移和偏移误差。 问候,Dana。 以上来自于百度翻译 以下为原文 Then why not eliminate OpAmp and AMUX2 and just add an input to AMUX1 for the TIA ? Or if using TIA with several, but not all, AMUX1 inputs, just eliminate OpAmp, no need for it, as it contributes more drift and offset error. Regards, Dana. |
ICANT摆脱Opamp,它不会编译没有块在那里。当我有一个MUX公共连接到任何其他AMUX时,它会出错。应该能够将8个输入中的任何一个连接到TIA。我想我已经决定用两个SARS而不是使用单一的SAR。
以上来自于百度翻译 以下为原文 I cant get rid of the Opamp, it wont compile without a block there. It errors when I have a mux common connected diirectly to any other amux. I need to be able to connect any of the 8 inputs to the TIA. Think i have just settled on using two SARs instead of using a single SAR. |
你好,
你不必浪费一个单位增益PGA,因为你面临的错误是连接一个AMUX的输出到另一个。 这里有一个简单的方法来摆脱它。 1。断开AMUX1和AMUX2的输出之间的连接。 2。在两者之间放置一个“网领带”组件。现在,“网络领带”组件将充当AMUXY1的输出与AMUXY2的输入之间的中介。 三。在Auxx1的输出和网络绑定组件之间的网络上放置一个网络约束组件,并将其配置选择为AMUXBUL。 4。同样,放净净的领带约束构件组件和amux_2的输入和选择是amuxbusr配置之间的线。 5。现在,如果你构建了这个项目,你就不会面临任何错误。 进一步的参考,我附上截图如何“顶层设计。cysch”看起来。 问候,Asha 阿姆苏溶液 44.3 K 以上来自于百度翻译 以下为原文 Hi, You need not waste a unity gain PGA because of ther error you are facing by connecting the output of one AMUX to another. Here is an easy way to get rid of it. 1. Break the connection between the output of AMUX_1 and AMUX_2. 2. Place a "Net Tie" component between the two. Now, the "Net Tie" component would act as a mediator between the output of AMUX_1 and the input of AMUX_2. 3. Place a net constraint component on the wire between AMUX_1's output and the net tie component and select its configuration to AMUXBUSL. 4. Similarly, place a net constraint component on the wire between net tie component and AMUX_2's input and select its configuration to be AMUXBUSR. 5. Now if you build the project, you will not face any error. For further reference, I have attached a screenshot of how the "TopDesign.cysch" would look. Regards, Asha
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1786 浏览 6 评论
1536 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
569浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
423浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
437浏览 2评论
383浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
915浏览 2评论
GMT+8, 2024-12-23 14:38 , Processed in 1.186812 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
