电子发烧友论坛|
您好,是否可以使用BenchVue控制DSO-X 3014A?
有空吗? 谢谢。 卢卡斯 以上来自于谷歌翻译 以下为原文 Hello, Is it possible to control DSO-X 3014A with BenchVue? Will it be available, when? Thank you. Lucas |
1个回答
你好卢卡斯,DSO-X 3014A与BenchVue兼容。
使用BenchVue,您可以轻松捕获和导出3014A示波器的屏幕截图和跟踪数据。 您可以使用来自具有BenchVue的3014A示波器的跟踪数据,在流行的Agilent功能发生器(如33220A和33521A / B)上创建任意波形。 您还可以使用BenchVue Mobile应用程序通过Android或iOS设备访问3014A示波器。 请注意,BenchVue为3014A示波器提供有限的控制功能,因此您仍然需要使用前面板来设置和执行测量(在大多数情况下)。 BenchVue更像是一种用于查看,捕获和导出3014A示波器测量数据的工具。 如果您是BenchVue的新手,我建议您访问www.agilent.com/find/benchvuevideos,查看视频“BenchVue入门”。您可以从www.agilent.com/find/benchvue免费下载BenchVue。希望这是有帮助的 感谢您对BenchVue的关注。 尼尔 以上来自于谷歌翻译 以下为原文 Hello Lucas, The DSO-X 3014A is compatible with BenchVue. With BenchVue you can easily capture and export screen shots and trace data from your 3014A scope. You can create an arbitrary waveform on popular Agilent function generators like the 33220A and the 33521A/B using trace data from your 3014A scope with BenchVue. You can also access your 3014A scope with your Android or iOS device using the BenchVue Mobile app. Please note that BenchVue provides limited control features for your 3014A scope so you will still have to use the front panel to setup and execute your measurement (in most cases). BenchVue is more of a tool for viewing, capturing, and exporting measurement data from the 3014A scope. If you are new to BenchVue I would recommend checking out the video "Getting Started with BenchVue" at www.agilent.com/find/benchvuevideos You can download BenchVue at no cost from www.agilent.com/find/benchvue Hope this was helpful and thanks for your interest in BenchVue. Neil |
只有小组成员才能发言,加入小组>>
273 浏览 0 评论
1868 浏览 0 评论
2755 浏览 1 评论
2657 浏览 1 评论
2477 浏览 5 评论
1870浏览 0评论
434浏览 0评论
278浏览 0评论
/9
GMT+8, 2025-12-13 21:08 , Processed in 0.645591 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3004
