你好,
谁能帮我找到GPIO中断定时描述配置? 枚举类型的声明cyu3pgpiointrmode_t { cy_u3p_gpio_no_intr = 0,/ * * / cy_u3p_gpio_intr_pos_edge没有中断触发,/*中断触发输入的上升沿。* / / * cy_u3p_gpio_intr_neg_edge,中断触发输入负的边缘。* / / * cy_u3p_gpio_intr_both_edge,中断触发边缘的输入。* / / * cy_u3p_gpio_intr_low_level,中断触发输入低电平。* / / * cy_u3p_gpio_intr_high_level,中断触发输入高电平。* / / * cy_u3p_gpio_intr_timer_thres,中断时触发定时器入门。仅适用于复杂的GPIO引脚。* / / * cy_u3p_gpio_intr_timer_zero中断时触发计时器达到零。仅适用于复杂的GPIO引脚。*/} CYU3PGPIONETMODEDET; 一个信号要多久,一个中断执行的情况下低/高? 需要多长时间如果我用积极的边缘到边缘的检测? 谢谢, 隆皮 以上来自于百度翻译 以下为原文 Hello, can someone help me to find timing description for the GPIO interrupt configurations? typedef enum CyU3PGpioIntrMode_t { CY_U3P_GPIO_NO_INTR = 0, /* No Interrupt is triggered*/ CY_U3P_GPIO_INTR_POS_EDGE, /* Interrupt is triggered for positive edge of input. */ CY_U3P_GPIO_INTR_NEG_EDGE, /* Interrupt is triggered for negative edge of input. */ CY_U3P_GPIO_INTR_BOTH_EDGE, /* Interrupt is triggered for both edge of input. */ CY_U3P_GPIO_INTR_LOW_LEVEL, /* Interrupt is triggered for Low level of input. */ CY_U3P_GPIO_INTR_HIGH_LEVEL, /* Interrupt is triggered for High level of input. */ CY_U3P_GPIO_INTR_TIMER_THRES, /* Interrupt is triggered when the timer crosses the threshold. Valid only for complex GPIO pin. */ CY_U3P_GPIO_INTR_TIMER_ZERO /* Interrupt is triggered when the timer reaches zero. Valid only for complex GPIO pin. */ } CyU3PGpioIntrMode_t; How long has a signal to be, that a interrupt is executed in case of low-/, high-level? How long does it take if I use positive edge till the edge is detected? Thanks, lumpi |
2个回答
嗨,Lumpi,
输入信号必须大于100纳秒,以检测正或负边缘。 如果你观察到与此不同的东西,请告诉我。 谢谢, 西克里希纳。 以上来自于百度翻译 以下为原文 Hi Lumpi, The input signal has to be more than 100 ns for either positive or negative edge to be detected. Please let me know if you observe anything different from this. Thanks, sai krishna. |
嗨,Sai Krishna,
谢谢你的回答,那是我喜欢知道的一切,棒极了。 当做, 隆皮 以上来自于百度翻译 以下为原文 Hi Sai Krishna, thanks for your answer, that was everything I liked to know, awesome. regards, lumpi |
只有小组成员才能发言,加入小组>>
740个成员聚集在这个小组
加入小组1991 浏览 1 评论
1752 浏览 1 评论
3532 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1683 浏览 6 评论
1459 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
245浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
149浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
343浏览 2评论
289浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
474浏览 2评论
GMT+8, 2024-9-8 20:24 , Processed in 0.881112 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
