电子发烧友论坛|
嗨,您对MSO6104A建议使用哪些差分探头?
它的带宽应该与示波器的带宽相同吗? 谢谢,塞尔丘克 以上来自于谷歌翻译 以下为原文 Hi, What differential probes do you suggest for MSO6104A? Should its bandwidth be the same as the oscilloscope's? Thanks, Selcuk |
1个回答
较低的BW(一般情况下,示波器和探头都应该比您认为需要的BW更高。在您的情况下,如果您想要从系统中取出完整的BW,可能会建议使用1.5GHz BW探头。
。免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。安捷伦论坛将在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 Lower BW (<2GHz) Oscilloscopes tend to have a Gaussian rolloff, meaning that their response is down 3dB at rated BW. Probes in this range also have a Gaussian rolloff. If, for example, you put a 1GHz probe on a 1GHz scope, all you know is that you are down about 6dB at 1GHz. In general, the scope and the probe should both be a higher BW than what you think you need. In your case, a 1.5GHz BW probe would probably be recommended, at least, if you want full BW out of the system. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
315 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2659 浏览 1 评论
2480 浏览 5 评论
1872浏览 0评论
438浏览 0评论
317浏览 0评论
/9
GMT+8, 2025-12-18 01:57 , Processed in 0.771766 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
643
