电子发烧友论坛|
嗨,我的办公室有一个MSO6104a示波器,我不知道为什么,但是示波器不允许我测量直流信号。
它配置得很好(在探头选项中我选择了DC耦合)。 当我接通电源时(除了示波器之外没有连接任何东西),我有一个峰值和一个像放电电容器的信号,信号变为0.然后它仍然是这样的(即使关闭和供电) 。 我必须测量地面以获得负峰值和信号,如电容器充电。 你能帮我解决这个问题吗? 谢谢你,JohanEdited:johandesmyter于2013年3月6日上午6:47 以上来自于谷歌翻译 以下为原文 Hi, I have a MSO6104a scope at my office and i don't know why, but the scope do not allow me to measure dc signals. it is well configured (in the probe option i selected DC coupling) . When i power on the supply (not connected to anything but the scope), i have a peak and a signal like a discharging capacitor and the signal goes to 0. Then it remains like this (even if is switch off and on the supply). I have to measure the ground to get a negative peak and a signal like a capacitor charging. Can you help me with that issue? Thanks you, Johan Edited by: johandesmyter on Mar 6, 2013 6:47 AM |
2个回答
这是否会在所有渠道上发生?
尝试用户校准。 如果失败,或者无法解决问题,则需要修复范围。 人 以上来自于谷歌翻译 以下为原文 Does this happen on all channels? Try a user calibration. If that fails, or doesn't fix the problem, the scope needs to be repaired. Al |
探头是否完全插入/您是否尝试过其他探头?
我已经看到这种情况发生在其中一个连接几乎连接之前,但并不完全。 此外,您是否尝试将范围重置为默认设置? 以上来自于谷歌翻译 以下为原文 Is the probe plugged in all the way/have you tried another probe? I have seen this happen before when one of the connections was almost connected, but not quite. Also, did you try resetting the scope to the default settings? |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 14:19 , Processed in 0.660882 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1708
