嗨,DDR2+SRAM部件应该在数据线上有ODT…但我在iBIS模型中看不到。我在BWS和K/K*上看到了。
来自DDR2PB2L25YCY21XX.IBS的例子(您可以看到它在哪里表示驱动输出阻抗是什么,但是输入阻抗未知): [模型选择器] TATAIO TATAIO5050TT1.5 1.5数据模型(50OHMS)在TT条件下:1.5V I/O DATAIO5050FF1.51.5 DATAIO模型(50OHMS)在FF条件下:1.5V I/O DATAIO50TSFF1.5 1.5DATAIO模型(50OHMS)在tiP慢速条件下-1.5V I/O DATAIO30TTY1.5 1.5DATAIO模型(30OHMs)在TT条件下- 1在FF条件下的5V I/O DATAIO30FF1.51.5 DATAIO模型(30OHMs)-1.5V I/O DATAIO30TSF1.51.5 DATAIO模型(30OHMS)在TIP慢速条件下-1.5V I/O DATAIO40TT1.51.5 DATAIO模型(40OHMS)在TT条件下-1.5V I/O DATAIO40FF1.51.5 DATAIO模型(40OHMs)在FF条件下-1.5V I/O DATAIO40TYF1.51.5 DATAIO模型(40OHMS)在TYP慢速条件下-1.5V I/O DATAIO60TTY1.5 1.5DATAIO模型(60OHMS)在TT条件下-1.5V I/O DATAIO60FF1.51.5 DATAIO模型(60OHMS)在FF条件下1.5V I/O DATAIO60TSFF1.5 1.5DATAIO模型(60OHMS)在TIP慢速条件下-1.5V I/O DATAIO70TTY1.5TAT条件下的DATAIO模型(70OHMS)-1.5V I/O DATAIO70FF1.51.5 DATAIO模型(70OHMs)在FF条件下-1.5V I/O 谢谢您。 以上来自于百度翻译 以下为原文 Hi, the DDR2+ SRAM parts are supposed to have ODT on the DATA lines... but I don't see it in the ibis model. I see it on the BWS and K/K* though. Example from ddr2pb2l25_cy21xx.ibs (You can see where it says what the driving output impedance is, but the input impedance is unknown): [Model Selector] DATAIO | DATAIO50_TT_1.5 DATAIO models (50ohms) at TT conditions - 1.5V I/O DATAIO50_FF_1.5 DATAIO models (50ohms) at FF conditions - 1.5V I/O DATAIO50_TSF_1.5 DATAIO models (50ohms) at Typ Slow Fast conditions- 1.5V I/O DATAIO30_TT_1.5 DATAIO models (30ohms) at TT conditions - 1.5V I/O DATAIO30_FF_1.5 DATAIO models (30ohms) at FF conditions - 1.5V I/O DATAIO30_TSF_1.5 DATAIO models (30ohms) at Typ Slow Fast conditions- 1.5V I/O DATAIO40_TT_1.5 DATAIO models (40ohms) at TT conditions - 1.5V I/O DATAIO40_FF_1.5 DATAIO models (40ohms) at FF conditions - 1.5V I/O DATAIO40_TSF_1.5 DATAIO models (40ohms) at Typ Slow Fast conditions- 1.5V I/O DATAIO60_TT_1.5 DATAIO models (60ohms) at TT conditions - 1.5V I/O DATAIO60_FF_1.5 DATAIO models (60ohms) at FF conditions - 1.5V I/O DATAIO60_TSF_1.5 DATAIO models (60ohms) at Typ Slow Fast conditions- 1.5V I/O DATAIO70_TT_1.5 DATAIO models (70ohms) at TT conditions - 1.5V I/O DATAIO70_FF_1.5 DATAIO models (70ohms) at FF conditions - 1.5V I/O Thank you. |
2个回答
你好,韦斯特克,
数据输入也有ODT。请确认您是否在以下链接中引用最新的IIS模型: HTTP://www. CyPress?COM/?RID=48344 下面是IIS模型中的ODT缓冲区模型。 [模型选择器]输入板 在TT条件下输入525TTH1.5 1.5输入模型(52.5OHMs)-1.5V I/O 在FF条件下输入525FFF1.5输入模型(52.5欧姆)-1.5V I/O 在TypSlowFast条件下输入525TSFF1.5输入模型(52.5OHMs)-1.5V I/O 在TT条件下输入输入模式(75欧姆)-1.5V I/O 在FF条件下输入输入模式(75欧姆)-1.5V I/O 输入条件:TypSlowFast条件下输入模式(75欧姆)-1.5V I/O 在TT条件下输入- 90TTH1.5 1.5输入模式(90欧姆)-1.5V I/O 在FF条件下输入90FFF1.5输入模式(90欧姆)-1.5V I/O 输入条件90-TSF1.51.5输入模式(90欧姆)在TypSlowFast条件-1.5V I/O 在TT条件下输入105TTH1.5 1.5输入模型(105OHMs)-1.5V I/O 在FF条件下输入105FFF1.5输入模型(105OHMs)-1.5V I/O 在TypSlowFast条件下输入105TSFF1.5输入模型(105OHMs)-1.5V I/O 在TT条件下输入模式150(150欧姆)-1.5V I/O 在FF条件下输入输出模式(150欧姆)-1.5V I/O input150_tsf_1.5输入模型(150ohms)在TypSlowFast条件Vgs=- 1.5V的I / O input525_tt_1.8输入模型(52.5ohms)在TT条件为1.8V的I / O input525_ff_1.8输入模型(52.5ohms)在FF条件为1.8V的I / O input525_tsf_1.8输入模型(52.5ohms)在TypSlowFast条件为1.8V的I / O input75_tt_1.8输入模型(75ohms)在TT条件为1.8V的I / O input75_ff_1.8输入模型(75ohms)在FF条件为1.8V的I / O input75_tsf_1.8输入模型(75ohms)在TypSlowFast条件为1.8V的I / O input90_tt_1.8输入模型(90ohms)在TT条件为1.8V的I / O input90_ff_1.8输入模型(90ohms)在FF条件为1.8V的I / O input90_tsf_1.8输入模型(90ohms)在TypSlowFast条件为1.8V的I / O input105_tt_1.8输入模型(105ohms)在TT条件为1.8V的I / O input105_ff_1.8输入模型(105ohms)在FF条件为1.8V的I / O input105_tsf_1.8输入模型(105ohms)在TypSlowFast条件为1.8V的I / O input150_tt_1.8输入模型(150ohms)在TT条件为1.8V的I / O input150_ff_1.8输入模型(150ohms)在FF条件为1.8V的I / O input150_tsf_1.8输入模型(150ohms)在TypSlowFast条件为1.8V的I / O 当做 贾亚斯里 以上来自于百度翻译 以下为原文 Hi Westec, The data inputs also have ODT.Please confirm whether you are referring to the latest IBIS model on the web in link below: http://www.cypress.com/?rID=48344 Below are the ODT buffer model in the IBIS model. [Model Selector] INPAD INPUT525_TT_1.5 INPUT models(52.5ohms) at TT conditions - 1.5V I/O INPUT525_FF_1.5 INPUT models(52.5ohms) at FF conditions - 1.5V I/O INPUT525_TSF_1.5 INPUT models(52.5ohms) at TypSlowFast conditions- 1.5V I/O INPUT75_TT_1.5 INPUT models (75ohms) at TT conditions - 1.5V I/O INPUT75_FF_1.5 INPUT models (75ohms) at FF conditions - 1.5V I/O INPUT75_TSF_1.5 INPUT models (75ohms) at TypSlowFast conditions- 1.5V I/O INPUT90_TT_1.5 INPUT models (90ohms) at TT conditions - 1.5V I/O INPUT90_FF_1.5 INPUT models (90ohms) at FF conditions - 1.5V I/O INPUT90_TSF_1.5 INPUT models (90ohms) at TypSlowFast conditions- 1.5V I/O INPUT105_TT_1.5 INPUT models (105ohms) at TT conditions - 1.5V I/O INPUT105_FF_1.5 INPUT models (105ohms) at FF conditions - 1.5V I/O INPUT105_TSF_1.5 INPUT models (105ohms) at TypSlowFast conditions- 1.5V I/O INPUT150_TT_1.5 INPUT models (150ohms) at TT conditions - 1.5V I/O INPUT150_FF_1.5 INPUT models (150ohms) at FF conditions - 1.5V I/O INPUT150_TSF_1.5 INPUT models (150ohms) at TypSlowFast conditions- 1.5V I/O INPUT525_TT_1.8 INPUT models(52.5ohms) at TT conditions - 1.8V I/O INPUT525_FF_1.8 INPUT models(52.5ohms) at FF conditions - 1.8V I/O INPUT525_TSF_1.8 INPUT models(52.5ohms) at TypSlowFast conditions- 1.8V I/O INPUT75_TT_1.8 INPUT models (75ohms) at TT conditions - 1.8V I/O INPUT75_FF_1.8 INPUT models (75ohms) at FF conditions - 1.8V I/O INPUT75_TSF_1.8 INPUT models (75ohms) at TypSlowFast conditions- 1.8V I/O INPUT90_TT_1.8 INPUT models (90ohms) at TT conditions - 1.8V I/O INPUT90_FF_1.8 INPUT models (90ohms) at FF conditions - 1.8V I/O INPUT90_TSF_1.8 INPUT models (90ohms) at TypSlowFast conditions- 1.8V I/O INPUT105_TT_1.8 INPUT models (105ohms) at TT conditions - 1.8V I/O INPUT105_FF_1.8 INPUT models (105ohms) at FF conditions - 1.8V I/O INPUT105_TSF_1.8 INPUT models (105ohms) at TypSlowFast conditions- 1.8V I/O INPUT150_TT_1.8 INPUT models (150ohms) at TT conditions - 1.8V I/O INPUT150_FF_1.8 INPUT models (150ohms) at FF conditions - 1.8V I/O INPUT150_TSF_1.8 INPUT models (150ohms) at TypSlowFast conditions- 1.8V I/O regards Jayasree |
嗨,Jayasree,
是的,这是一个很好的例子模型(我已经看过DealalCio模型……一切非常相似。 InPad确实有ODT,但没有分配给数据。数据使用DATAIMODEL(我粘贴的一个)检查[PIN ]列表: B2-DQ27数据 再次感谢约瑟夫 以上来自于百度翻译 以下为原文 Hi Jayasree, Yes that's a good example model (I've looked at several CIO models... all very similar.) The INPAD does have ODT, but is not assigned to Data. Data use the DATAIO model (the one I pasted.) Check the [Pin] list: B2 DQ27 DATAIO Thanks again, Joseph |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2098 浏览 1 评论
1845 浏览 1 评论
3664 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1782 浏览 6 评论
1532 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
556浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
410浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
433浏览 2评论
379浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
905浏览 2评论
GMT+8, 2024-12-18 20:05 , Processed in 1.041489 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
