嗨我的设备是8510A。
我从安捷伦网站下载了Cal Kit Manager。 我使用这个软件将一些校准套件加载到8510 A CAL套件内存并且这是正确的,但现在我无法将任何校准套件数据发送到8510内存。 显然我的8510A CAL Kit内存已损坏或已满。 你能救我吗? 谢谢Yasamin 以上来自于谷歌翻译 以下为原文 Hi My device is 8510A. I've downloaded the Cal Kit Manager from Agilent site. I loaded some cal kit to the 8510 A CAL kit memory by using this software and It was correct, but now I can not send any cal kit data to the 8510 memory. Apparently my 8510A CAL Kit memory is corrupted or full. May you help me? thanks Yasamin |
4个回答
> {quote:title = yasamin写道:} {quote}>嗨>我的设备是8510A。
>我从安捷伦网站下载了Cal Kit Manager。 >我使用这个软件将一些校准套件加载到8510 A CAL套件内存,这是正确的,但现在我无法将任何校准套件数据发送到8510内存。 >显然我的8510A CAL Kit内存已损坏或已满。 >>你能帮帮我吗? >>谢谢> Yasamin我从未见过8510系列VNA,但我相信只有两个用户定义的校准套件可以存储 - 这比我的8720还多! 也许先尝试删除一个。 戴夫 以上来自于谷歌翻译 以下为原文 > {quote:title=yasamin wrote:}{quote} > Hi > My device is 8510A. > I've downloaded the Cal Kit Manager from Agilent site. > I loaded some cal kit to the 8510 A CAL kit memory by using this software and It was correct, but now I can not send any cal kit data to the 8510 memory. > Apparently my 8510A CAL Kit memory is corrupted or full. > > May you help me? > > thanks > Yasamin I have never seen an 8510 series VNA, but I believe there are only two user defined cal kits you can store - which is one more than my 8720 !! Perhaps try deleting one first. Dave |
60user7 发表于 2019-2-14 16:58 是的,8510有两个用户定义的校准套件。 但是,我不知道如何删除它们。 我可以手动删除校准套件内存吗? 我没有在8510的前面板上看到任何用于此目的的按键或软键。你可以帮助我吗? 谢谢yasamin 以上来自于谷歌翻译 以下为原文 Yes, 8510 has two user defined cal kits. But, I do not know how to delete them. Can I delete the cal kit memory manually? I did not see any key or softkey for this purpose in the front panel of 8510. May you help me? thanks yasamin |
您好我可以使用Cal Kit Manager 2.1将校准套件数据发送到我的8510A,但显然数据不正确。
标准图标签错误,也不会手动修改。 你能救我吗? 谢谢yasamin 以上来自于谷歌翻译 以下为原文 Hi I could send the cal kit data to my 8510A by using Cal Kit Manager 2.1, but apparently the data is not correct. The standarad labels are wrong and do not modified manually too. May you help me? Thanks yasamin |
您好我通过使用磁带将我的校准套件数据加载到8510 A CAL套件内存并且它是正确的。
我的问题解决了。 但我不知道问题是什么? (当我尝试使用VNA校准套件管理器2.1将校准套件数据加载到8510时)感谢Yasamin 以上来自于谷歌翻译 以下为原文 Hi I loaded my cal kit data to the 8510 A CAL kit memory by using the tape and It is correct. My problem is solved. But I do not know what the problem is? (when I tried to load the cal kit data to 8510 by using VNA cal kit manager 2.1) thanks Yasamin |
只有小组成员才能发言,加入小组>>
1133 浏览 0 评论
2321 浏览 1 评论
2114 浏览 1 评论
1985 浏览 5 评论
2859 浏览 3 评论
882浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
651浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
753浏览 0评论
1451浏览 0评论
1139浏览 0评论
GMT+8, 2024-10-21 00:15 , Processed in 1.445717 second(s), Total 84, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
