我曾经使用MPLAB XIDE 3.45和3.51来编程我的PIC32以太网启动器套件,没有问题。我买了一台新的计算机,它运行在Windows 10专业版上。今天我下载了MPLAXIDE3.65,并使用了以太网启动工具包II。但是,以前工作过的X项目不能通过。我使用XC32(1.44)编译器,并且构建没有问题。输出窗口如下:*************************************************************************************************************************************************************************************************************************************************************************************************************************************BooDealSudioSudio版本…01.31.20*固件类型……未知固件TyjeNo下载目标设备的新固件:PIC32 mX795F512L下载BooDooBooBooLoad下载完成编程下载……*******************,然后它似乎停留在那里超过20分钟没有响应。我试过XIDE 3.45和XIDE 3.51在我的旧电脑上,它很快输出“连接失败”。任何人都可以帮助解决这个问题?我需要在我的计算机上下载PIC32以太网启动器套件II的任何新驱动程序吗?非常感谢你。
以上来自于百度翻译 以下为原文 I used to use MPLab XIDE 3.45 and 3.51 to program my PIC32 Ethernet Starter Kit, and there is no problem. I purchased a new computer, and it runs on Windows 10 professional. Today I downloaded MPLab XIDE3.65, and use the Ethernet Starter Kit II . However, the same X project worked before can not go through. I use the xc32 (1.44) compiler, and build has no problem. The output window says below: ********************************************* Connecting to Starter Kit on Board... Currently loaded firmware on Starter Kit on Board Firmware Suite Version.....01.31.20 * Firmware type..............Unknown Firmware Type Now Downloading new Firmware for target device: PIC32MX795F512L Downloading bootloader Bootloader download complete Programming download... ******************************************** Then it seems stuck there for more than 20 minutes without responding. I tried xIDE 3.45 and xIDE 3.51 on my old computer, it quickly output "connection failed" . Anyone can help on this issue ? Do I need to download any new drivers for the PIC32 Ethernet Starter Kit II on my computer ? Thank you very much in advance. Attached Image(s) |
7个回答
嗨,你的初学者工具包需要重新加载一个新的固件,但由于MPLAB X V3.65的原因,第一次尝试大多是不成功的。成功的最好方法是把你的工具包连接到另一个版本的MPLAX计算机上,然后再试一次。这个FRUM上的几个用户有这个问题,最后成功了。
以上来自于百度翻译 以下为原文 Hi, your starter kit need to reload automatically a new firmware but for some reason with MPLAB X v3.65, the first attempt is mostly unsuccessful. the best way to succeed is to connect you kit back to a computer with another version of MPLAB X and then try again. Several users on this frum had this issue and finally succeeded. Regards |
谢谢RISC的回复。关于这件事的早期讨论有什么联系,我可以暗示一下吗?实际上,在我发布线程之前我就这么做了。我在我的旧电脑上试用了XIDV3.45和XIDV3.51。他们很快输出“连接失败”。这是否意味着固件重新加载成功?然后我用XIDV3.65再次尝试,但是它坚持了很长时间。有什么评论、建议、建议吗?谢谢!
以上来自于百度翻译 以下为原文 Thanks RISC for your reply. Is there a link for the earlier discussion on this matter that I can have a hint ? Actually I did this before I post the thread. I tried with xIDE V3.45 and xIDE V3.51 on my old computer. They quickly output "connection failed". Does this mean firmware reloaded successfully ? Then I tried again with the xIDE v3.65, but it stuck for long time. Any comment, suggestion, advice? Thanks! |
我附加了一个屏幕显示,显示固件重新加载成功,但代码下载卡住。
以上来自于百度翻译 以下为原文 I attached a screen shot showing firmware reloaded successfully but code downloading stuck. Attached Image(s) |
好啊。我终于明白了这一点。我发现了一个帖子:HTTPS://www. McCHIP.COM/FUMMS/M/TM.ASPX?M=1004916和FP= 1IT表明,问题是USB连接到以太网启动器套件II,它吸引更多的电流,由于其以太网子板,并且是非常敏感的USB电压。我删除了女儿板,但同时我把电源(5V 2A)插入到我的USB集线器,所以起动器工具箱II可以获得更多的电力(稳定的电压和更大的电流)。然后编程下载是成功的,如附图截图所示。所以我认为问题不在软件方面。但是启动套件II比标准USB端口在我的计算机上提供更多的电流,并导致轻微的电压下降。不幸的是,初学者工具包II不接受这个电压降,拒绝将程序写入闪存。使用具有足够外部电源的USB集线器似乎是解决这个问题的方法。它对我有用。希望这对那些有类似问题的人是有帮助的。谢谢,
以上来自于百度翻译 以下为原文 OK. I finally figured this out. I found a thread posted before: https://www.microchip.com/forums/m/tm.aspx?m=1004916&fp=1 It suggests that the issue is the USB connection to the Ethernet Starter Kit II, which draws more current due to its Ethernet daughter board, and is very sensitive to the USB voltage. I did removed the daughter board, but simultaneously I plug the power supply (5V 2A) to my USB hub, so the Starter Kit II can get more power(stable voltage and larger current). And then the programming download is successful, as shown in attached screen shot. So I think the problem is not at the software side. But the Starter Kit II draws more current than the standard USB port can provide on my computer and causes a slight voltage drop. Unfortunately Starter Kit II does not accept this voltage drop and refuse to write the program into the flash memory. To use an USB hub with a sufficient external power supply seems the solution for this problem. It works for me. Hope this is helpful for those who have similar problem. Thanks, |
我不知道为什么,但是我不能上传我的截图。不管怎样,它现在起作用了。
以上来自于百度翻译 以下为原文 I don't know why, but I can not upload my screenshot. Anyway, it works now. |
嗨,你能在你的标题中加上[解决]吗?谢谢
以上来自于百度翻译 以下为原文 Hi, Can you please add [SOLVED] to your thread title ? Thanks |
只有小组成员才能发言,加入小组>>
4926 浏览 9 评论
1876 浏览 8 评论
1817 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3018 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2106 浏览 5 评论
521浏览 1评论
375浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
426浏览 0评论
314浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
796浏览 0评论
GMT+8, 2024-7-16 18:29 , Processed in 2.205717 second(s), Total 109, Slave 93 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
