电子发烧友论坛|
嗨,我目前正在研究一个模拟设备BLIMFIN与CYFR6936接口。我已经写了司机模仿WirelessUSB LP驱动1.4柏PSoCs尽量紧密,但它是不稳定的。在发送和接收的几秒钟,rxberr IRQ的断言,我不能断定。阅读的TX和RX irq_status寄存器似乎不清楚,所以我继续射击连续中断。数据表说:“这个标志被清除时,RX去设置和SOP接收,“但这是一段在传输过程中发生的,而另一端是不会发送任何东西因为它在等待一个包。如何获得RXBIRR IRQ去断言,这样我的ISR停止射击?
以上来自于百度翻译 以下为原文 Hi, I'm currently working on a Analog Devices Blackfin interfacing with a CYRF6936. I've written the driver to mimic the WirelessUSB LP Driver 1.4 for Cypress PSoCs as closely as possible, but it's unstable. After several seconds of transmitting and receiving, the RXBERR IRQ is asserted, and I can't get it to de-assert. Reading the TX and RX IRQ_STATUS registers doesn't seem to clear it, so my interrupt keeps on firing continuously. The datasheet says "this flag is cleared when RX GO is set and a SOP is received," but this is happening during a period of transmission, and the other end isn't going to be transmitting anything because it's waiting for a packet. How do I get RXBERR IRQ to de-assert so my ISR stops firing? |
2个回答
尽量不要使这个中断出现在IRQ PIN上,而只是在必要的时候通过读取状态寄存器来检查
以上来自于百度翻译 以下为原文 try not enabling this interrupt to be present on IRQ pin, rather just examine by reading status register if/when necessary |
Anitha,你是对的。这是你可以期待中断和获取RXBIRR IRQ位集的唯一的两种方式。问候,Sai
以上来自于百度翻译 以下为原文 Anitha, You are right .This are the only two ways where you can expect an interrupt and get the RXBERR IRQ bit set. Regards, Sai |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:52 , Processed in 0.629236 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
520
