电子发烧友论坛|
您好,我目前正在使用PIC16F1829的项目,但我的问题是使用软件配置的弱拉I,当我用万用表测量时,似乎只有1.5V。我想在数据表中澄清一下,但我找不到。一个弱的拉力只有1.5V是正常的吗?我想它会是5。我正在通过5V的设置为电路供电。任何帮助都非常感谢。
以上来自于百度翻译 以下为原文 Hello, Im currently working on a project using the pic16f1829 but the problem I am having is the the weakpull I configured using software seems to only be 1.5v when I measure it with my multimeter. I was looking for some clarification on this in the data sheet but I couldn't find any. Is it normal for a weak pull up to only be 1.5v I would think it would be 5? I am powering the circuit through the programmer on a setting of 5v. Any help is greatly appreciated thanks. |
4个回答
你使用的仪表的输入电阻/阻抗是用来测量引脚上的电压的?这可能足够低,以吸引足够的电流来显著地影响测量。
以上来自于百度翻译 以下为原文 What is the input resistance/impedance of the meter you are using to measure the voltage on the pin? This may be low enough to draw enough current to notably affect the measurement. |
如果你在你的原始文章中提到哪个PIN,我会省去很多猜测。我猜它是RA0或RA1。显然你的程序员仍然是连接的,正如你提到的,你从它那里得到了力量。程序员在PGD和PGC上有10K下拉电阻,它连接到RA0AN。D RA1。这将完美地解释低电压的FLPOM弱脉冲。要么供电另一种方式,或尝试任何其他引脚。
以上来自于百度翻译 以下为原文 I would have saved a lot of guesswork if you'd mentioned which pin in your original post. I'm going to guess it's RA0 or RA1. Plainly you have the programmer still connected, as you mention you are getting power from it. The programmer has 10k pulldown resistors on PGD and PGC, which connect to RA0 and RA1. That would perfectly explain the low voltage frpom the WEAK pullups. Either supply power some other way, or try any other pins. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:46 , Processed in 0.703825 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3139
