电子发烧友论坛|
尊敬的ti工程师,您好:
我最近在学C5505,用的是官网的5505ezdsp开发板,在调试中断的时候一直调不通。 (1)是否我的配置有问题。 (2)vector.asm文件我添加到工程中,是不是添加的路径不对? (3)开发板自带的光盘里没有发现有定时器中断的程序,下边程序是我在其他地方找的,请问可否提供一下定时器0中断的例程。谢谢! 程序如下: void Timer0Init() [ CSL_Status status; CSL_Config hwConfig; CSL_GptObj gptObj; /* Open the CSL GPT module */ hGpt = GPT_open (GPT_0, &gptObj, &status); /* Reset the GPT module */ status = GPT_reset(hGpt); /* Timer interval 0.5sec (2Hz)*/ hwConfig.autoLoad = GPT_AUTO_ENABLE; hwConfig.ctrlTim = GPT_TIMER_ENABLE; hwConfig.preScaleDiv = GPT_PRE_SC_DIV_11; // Pre scale Divide input clock by 4096 // 98.304M/4096 = 24K hwConfig.prdLow = 0x2E00; // 24K/12K = 2Hz (12K = 0x2EE0) hwConfig.prdHigh = 0x0000; /* Configure Timer0 */ status = GPT_config(hGpt, &hwConfig); /* Start timer */ GPT_start(hGpt); ] /* * Timer_isr( ) * Timer 0 interrupt service routine. This function is called * whenever ther is a Timer interrupt. */ interrupt void tim_isr() [ //USBSTK5505_LED_on(0); /* Clear timer int flag */ CSL_CPU_REGS->IFR0 &= 0x0010; /* Clear timer0 int flag */ CSL_TIM_0_REGS->TIMINT = 0x0001; /*Clear Timer0 bit in Timer Aggregate register */ CSL_SYSCTRL_REGS->TIAFR |= 0x0001 ; fTimer=1; ] main() [ Timer0Init(); while(1) [ if (fTimer==1) USBSTK5505_LED_on(0); ] ] |
3 个讨论
请问中断使能了吗?可以参考csl里的例程c55_lpc55_csl_3.06ccs_v6.x_examplesgptCSL_GPT_NestedIntrNmiExample。
http://software-dl.ti.com/dsps/dsps_public_sw/dsps_swops_houston/C55X/latest/index_FDS.html /* Clear any pending interrupts */ IRQ_clearAll(); /* Disable all the interrupts */ IRQ_disableAll(); IRQ_setVecs((Uint32)(&VECSTART)); IRQ_plug(TINT_EVENT, &gptIsr); IRQ_enable(TINT_EVENT); |
您好,我也在学习调定时器中断。在程序中加入下面代码:
IRQ_setVecs((Uint32)(&VECSTART)); IRQ_plug(TINT_EVENT, &gpt0Isr); IRQ_enable(TINT_EVENT); cmd文件就报错,请问一下知道什么原因吗? SECTIONS { vectors (NOLOAD) > VECS // 、、、、、、、、、、、此处报错 .cinit > DARAM0 /* Arbitrary assignment of memory segments to .text section. */ /* Can be expanded or reduced observing limitations of SPRAA46 */ .text >> SARAM0|SARAM1|SARAM2|SARAM3|SARAM4 .stack > DARAM0 .sysstack > DARAM0 .sysmem > DARAM4 .data > DARAM4 .cio > DARAM0 .bss > DARAM5 .const > DARAM0 .switch > DARAM7 } |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 06:28 , Processed in 1.005352 second(s), Total 48, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1795
