电子发烧友论坛|
我发现各种安捷伦示波器产品在垂直位置/偏移的极性读数方面存在一个有趣的差异。
在我的Agilent U1602A手持式示波器上,如果我在示波器上向上调整波形(相对于零基线的正偏移),数字显示实际上显示正偏移读数(例如偏移= +1.0 V)如果我在我的上做同样的事情 U1620A(安捷伦手持式示波器的较大版本),向上移动波形会产生负偏移读数,向下移动会产生正偏移读数。 这让我很困惑,所以我查看了另一个安捷伦示波器(4000系列),并且在向正方向移动波形时也显示负偏移数。 我之前没有注意到这一点,但通常我习惯于期望Y轴上向上移动产生正偏移,并发现这种反直觉。 有人可以解释这种行为和理由吗? 但无论理论如何,两个手持式安捷伦示波器的工作方式都不同,这使得它更加令人费解。 我想这取决于你的背景是什么是“参考”---但如果我有,例如,0-5V方波和基线(0伏)坐在屏幕的中心X轴 - - 然后我调整波形“向上”,比如1伏(这样波形在1到6V之间,显示屏显示偏移为-1.0V。真的吗?不是偏移1V?还是在说 我需要“加”-1V来获得真正的读数?当然,这与减去1V相同 - 从向上=正偏移和向下=负偏移的角度来看,似乎更直观。我 我对其他人对其示波器的看法感兴趣,以及为什么不同型号的安捷伦示波器会不同地处理垂直偏移/位置。谢谢! 以上来自于谷歌翻译 以下为原文 I am seeing an interesting discrepancy between various Agilent scope products relating to the polarity reading of the Vertical Position/Offset. On my Agilent U1602A handheld scope, if I adjust the waveform upwards on the scope (positive offset relative to zero baseline), indeed the numerical display shows a positive offset reading (e.g. Offset = +1.0 V) If I do the same thing on my U1620A (a larger version of Agilent handheld scope), moving the waveform up causes a negative offset reading, and moving it down causes a positive offset reading. This puzzles me, so I looked on another Agilent scope I have (4000 series) and it also shows a negative number for offset when moving the waveform in the positive direction. I hadn't noticed this before, but typically I'm accustomed to expecting a positive offset resulting from a move upwards on the Y axis and find this counter-intuitive. Can someone explain this behavior and the rationale? But whatever rationale exists, two handheld Agilent scopes work differently, which makes it even more puzzling. I suppose it depends on your context for what is the "reference" --- but if I have, for example, a 0-5V square wave and the baseline (0 volts) is sitting on the center X-axis of the screen -- and then I adjust the waveform "upward" by, say 1 volt (such that now the waveform is between 1 and 6V, the display shows the offset as -1.0V. Really? Isn't the offset 1V? Or is it saying I need to "add" -1V to get the true reading? Of course, this is the same as subtracting 1V -- and it seems much more intuitive to think in terms of upward = positive offset, and downward = negative offset. I'm interested in what others see on on their scopes and why different models of Agilent scopes would treat vertical offset/position differently. Thanks! |
2个回答
U1602 / 04 / A / B只是一个奇怪的鸭子,可以这么说。
以上来自于谷歌翻译 以下为原文 The U1602/04/A/B is just an odd duck, so to speak. |
克里斯,谢谢你的澄清。
我现在了解基础。 我缺少的关键点是,在大多数安捷伦示波器的情况下,屏幕中心不一定是地面 - 而是相对于地面的规定偏移。 我正在考虑相反的方式 - 屏幕中心总是被称为接地(固定) - 并且偏移调整波形位置上下。 我再次确认U1602A / B的工作方式相反,中心线始终为0伏,偏移/位置上下调整波形。 正如@ksmith在早些时候的回复中所说,也许这个模型是该组织的“奇怪的鸭子”。 在产品线之间保持一致会很好,但至少我现在已经清楚了解它的工作方式背后的想法。 如果我更加关注轨迹上通道编号旁边的小“地面”符号,我会意识到偏差是如何计算的,以及为什么它看起来与你期望的极性相反。 U1602A / B在迹线旁边没有接地符号,因为接地始终以屏幕中心为参考。 以上来自于谷歌翻译 以下为原文 Chris, thanks for this clarification. I understand the basis now. The key point here that I was missing is that in the case of most Agilent scopes the center of the screen isn't necessarily the ground -- but the stated offset relative to ground. I was thinking of it the opposite way - that the center of the screen is always referred to ground (fixed) -- and the offset adjusts the waveform position up and down. I reconfirmed that the U1602A/B works in the opposite manner where the center line is always 0 volts and the offset/position adjusts the waveform up and down. As @ksmith stated in an earlier reply, maybe that model is the "odd duck" of the group. It would be nice to stay consistent between product lines, but at least I'm clear now on the thinking behind the way this works. Had I paid closer attention to the little "ground" symbol next to the channel number on the trace, I would have realized how offset was being computed and why it appears to be the opposite polarity of what you'd expect. The U1602A/B does not have the ground symbol next to the trace, since ground is always referenced to the center of the screen. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:08 , Processed in 0.470710 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1277
