电子发烧友论坛|
嗨,大家好,
到目前为止,我们已经通过FX3 DVK板通过SAMTEC J77连接到FPGA板没有问题。 现在我们的自定义板,FX3仍然成功枚举CyPress 04B4:00 F3 ID上电。 但之后,我们上传(任何)固件通过USB(无错误)在年底FX3断开,永远不会回来! 有什么想法吗? 最好的问候 格恩特 以上来自于百度翻译 以下为原文 Hi all, up to now we had worked with a FX3 DVK Board connected via Samtec J77 to a FPGA Board without problems. Now with our custom board the FX3 does still successfully enumerate with Cypress 04b4:00f3 id on power up. But then after we upload (any) firmware via USB (without error) at the end FX3 disconnects and never comes back! Any ideas what could be the reason? Best regards Günter |
17个回答
你好,京特,
我这里有几个问题。 当你说上传固件时,你是在编程RAM(SPI闪存)吗?EEPROM?? 你在PMODE引脚上得到合适的电压吗? 断开后在PC中显示的错误是什么? 你的董事会与FPGA有无关联?如果没有,请断开连接并尝试编程。 这里有可能分享你的原理图吗?如果不是,请创建一个技术支持案例(MyActudio & Gt;MyBox)。 -普吉 以上来自于百度翻译 以下为原文 Hello Gunter, I've a few questions here. When you say upload firmware, Are you programming RAM (SPI Flash?/ EEPROM?)? Are you getting proper voltage on PMODE pins ? What is the error being shown in PC after disconnect ? Is your board permenantly connected to FPGA? If not, please disconnect it and try programming. Is it possible to share your schematic here? If not, please create a tech support case (MyAccount -> MyCases). -PRJI |
你好,PJI,
谢谢您的快速回复! 关于你的问题: 我正在给RAM编程。 -保护模式前的所有准备销好因为FX3出现上电后正确的VID/PID,但是我会仔细检查一遍。 是保护模式前的所有准备相关也重新计算或引脚只有具有了吗? 没有错误后,就断开断开后规划已完成。 这是一个包括FPGA和FX3的单定制板。 关于图我问您尽快回来。 最好的问候 格恩特 以上来自于百度翻译 以下为原文 Hello PPJI, thank you for your fast reply! Regarding your questions: - I am programming to RAM. - PMODE pins are ok - since FX3 comes up with the correct VID/PID after power on, but I will double check again. Are the PMODE pins relevant also for re-numeration or only on opwer up? - there is no error shown after disconnect - it just disconnects after programming has finished. - It is a single custom board including FPGA and FX3 - Regarding the schematic I will ask and come back to you asap. Best regards Günter |
你好,PJI,
请在附件中找到示意图。 我们董事会的偏差是: -Q1是一个26 MHz振荡器,所以FSCL R32没有填充,但R33是 - J1根本没有连接,即GPIO51没有连接。 PMODE是“F1F” 与传统的工作解决方案与FX3 DVK板的唯一区别是26 MHz振荡器。 希望你能帮忙。 当做 格恩特 FX3.PDF 580.3 K 以上来自于百度翻译 以下为原文 Hello PPJI, please find the schematic in the attachment. Deviations to our board are: - Q1 is a 26 MHz oscillator so FSCL R32 is not populated but R33 is - J1 is not connected at all i.e GPIO51 is not connected PMODE is "F1F" The only difference to the old working solution with the FX3 DVK Board is the 26 MHz oscillator. Hope you can help. Regards Günter
你好,
请试用固件发布版本好吗? 当做 普拉吉斯 以上来自于百度翻译 以下为原文 Hi, Could you please try with release build of firmware ? Regards Prajith |
你好,
我们已经尝试了调试和发布版本。 结果是一样的。 当做 格恩特 以上来自于百度翻译 以下为原文 Hi, we already tried both Debug and Release builds. The result were the same. Regards Günter |
你好,普拉吉斯,
使用CyPress USB控制中心,我们至少能够加载CyPress程序员:ID04B4:720本身。 从硅引导加载程序开始,这意味着至少固件的重新计算工作。 所以我认为重新计算本身是有效的,但是FX3挂在引导上。 你能证实吗? 这似乎是一个类似的问题: HTTP://www. CyPress?COM/?APP =论坛和ID ID=167和;RID=62523 CyPress CyoBooProjter 04B4:47的项目源可用吗? 最好的问候 格恩特 以上来自于百度翻译 以下为原文 Hi Prajith, using the Cypress USB Control Center we at least are able to load the Cypress programmer: ID 04b4:4720 itself. Starting from the silicon boot loader this means at least the re-numeration for this firmware works. So I assume that re-numeration itself works but FX3 hangs on boot. Can you confirm? This here seems to be a similar problem: http://www.cypress.com/?app=forum&id=167&rID=62523 Is the project source of the cypress CyBootProgrammer 04b4:4720 available? Best regards Günter |
你好,
请尝试用theu***bulkloopauto.img.txtfile附inhttp://www.cypress.com/?APP =论坛和ID;ID=167和;RID=70377。 当做 普拉吉斯 以上来自于百度翻译 以下为原文 Hi, Please try with the USBBulkLoopAuto.img.txt file attached in http://www.cypress.com/?app=forum&id=167&rID=70377. Regards Prajith |
嗨,Gü中心,有dvkboard和自定义硬件方面gpioconnections之间有什么差别?请参见这里:
HTTP://www. CyPress?COM/?APP =论坛和ID ID=167和;RID=61087 你能把一个armdebugger看看固件是做什么的?史蒂夫 以上来自于百度翻译 以下为原文 Hi Günter, Is there any difference between the DVK board and your custom hardware with regard to GPIO connections? See here: http://www.cypress.com/?app=forum&id=167&rID=61087 Can you attach with an ARM debugger and see what the firmware is doing? Steve |
你好,普拉吉斯,
我们尝试了UBBulkLoopAut.img你张贴,它的工作! (至少它会恢复正常,后来就好了) 然而当我们试项目USBBulkLoopAuto(释放),自带的SDK 1.1不行。 有什么区别? 有必要更新我们的SDK吗? 当做 格恩特 以上来自于百度翻译 以下为原文 Hi Prajith, we tried the USBBulkLoopAuto.img you posted and it works! (at least it renumerates and comes up ok afterwards) However when we try the sample project USBBulkLoopAuto (Release) which comes with the SDK 1.1 it doesn't. What is the difference? Is it necessary to update our SDK? Regards Günter |
嗨,史提夫,
谢谢你的暗示! 我们已经对DVK和自定义板之间的GPIO连接进行了双重检查和比较,但没有区别。 关于ARM调试器的好主意。然而,由于它似乎与固件PrjthTh发布,我最好先尝试SDK更新。 当做 格恩特 以上来自于百度翻译 以下为原文 Hi Steve, thank you for the hint! We already double checked and compared the GPIO conections between DVK and custom board, but there is no difference. Good idea regarding the ARM debugger. However since it seems to work with the firmware Prajith posted I'll better first try a SDK update. Regards Günter |
嗨,G,N.
JLink调试器是个好主意。您可能有一个问题的电源超速源(RX TX)的FX3在您的董事会。如果在函数调用CYU3PUBCONTION(TRUE,TRUE)之后,USB断开或调试器失去连接,这是可能的。如果它连接到超高速就发生了。激活超高速PHY需要大量的电流。 当做 隆皮 以上来自于百度翻译 以下为原文 Hi Günter, the jlink debugger is a really good idea. You may have a problem with the power supply of the SuperSpeed sources (RX TX) of FX3 on your board. That can be possible if USB disconnects or debugger loses connection after the functin call CyU3PU***Connect(true, true). That just happens if it connect to superspeed. Activating the superspeed phy needs a lot of current. regards lumpi |
嗨,Lumpi,嗨!
谢谢你关于权力的暗示! 这使我们走上了正确的方向。现在我们很可能找到问题的根本原因。 在U3TXVDDQ和U3RXVDDQ的示意图中有一个错误。它们连接到错误的功率域: 使用最新的SDK 1.2.2也没有帮助。 在硬件固定之前,我们只想尝试使用高速板。 @ Prajith,你的UBBulkLoobe固件有什么变化? 你禁用超速了吗?你是怎么做到的? 你只调用CYU3pCONTCONSTATE(CyTrac,CyFalse)吗? 当做 格恩特 以上来自于百度翻译 以下为原文 Hi Lumpi, hi all, thank you for the hint regarding power! This brought us into the right direction. Now we most likely found the root cause of the problem. There is an error in the schematic regarding U3TXVDDQ and U3RXVDDQ. They are connected to the wrong power domain :-( Using the latest SDK 1.2.2 did not help also. Until the hardware is fixed we want to try to use the board with high speed only. @Prajith, what did you change in your USBBulkLoopAuto firmware? Did you disable superspeed? How did you do it? Did you only call CyU3PConnectState(CyTrue, CyFalse) ? Regards Günter |
你好,
很高兴听到你的问题解决了。 是的,我禁用了它。正如Lumbi指出的,我想检查SS块。 你是对的,cyu3pconnectstate(cytrue,CyFalse)工作。-普吉 以上来自于百度翻译 以下为原文 Hi, Happy to hear that your problem is solved Yes, I disabled it. As Lumbi pointed out I wanted to check SS block. [size=11.333333015441895px]You are right, [size=11.333333015441895px]CyU3PConnectState(CyTrue, CyFalse [size=11.333333015441895px]) should work. -PRJI |
嗨,普吉,
谢谢您的支持! FX3与USB2和“Cyu3pCeltTeStand(CyTress,CyFalse)”一起工作没有问题,我们的固件也。 在此期间,我们的外部服务提供商纠正了bug,并且重新工作的板现在也以超高速运行! 当做 格恩特 以上来自于百度翻译 以下为原文 Hi PRJI, thank you for your support! FX3 worked without problems with USB2 and "CyU3PConnectState(CyTrue, CyFalse)" with our firmware also. In the meantime our external service provider corrected the bug and the re-worked board now works also with SuperSpeed! Regards Günter |
我正面临着完全相同的问题。我需要做什么才能让硬件与USB 3一起工作?
以上来自于百度翻译 以下为原文 I am having the *exact* same problem. What do I need to do to the hardware to have it work with u*** 3.0? |
巧合的是,我使用的自定义硬件我设计的每一个文档…上面的文件执行得很好。
以上来自于百度翻译 以下为原文 Coincidentally, I am using custom hardware I designed per documentation... and the file above executed perfectly. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:16 , Processed in 1.833417 second(s), Total 106, Slave 89 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2866
