电子发烧友论坛|
我要找的文件,在这个文件hexpad.tar.gz www.cypress.com/提到。
我开发了一个基于Linux的USB设备,我想试试这个例子又。 我可以在哪里下载文件HEXADAD.TAR.GZ? 以上来自于百度翻译 以下为原文 I am looking for the file hexpad.tar.gz which is mentioned in this document www.cypress.com/ . As I develop a USB device for Linux, I would like to try this example again. Where can I download the file hexpad.tar.gz? |
4个回答
你好,Wudli,
正如你所要求的,请找到HPADAD示例攻击者(AN1170131.zip)。 请注意,CyPress不再支持这个应用笔记和相关的例子。我们正在升级Linux支持。但直到那时,我们的Linux支持是有限的。 同时,您可以使用第三方Linux支持。细节在KB文章(HTTP://wwwyCysP.COM/)中列出?ID=4和;RID=29746)。此外,对于Linux应用程序开发,您还可以使用第三方库LIPSUB(http://www. LubSB.org/)。 谢谢, 萨米尔 A1170S.13Zip 12.1 K 以上来自于百度翻译 以下为原文 Hello Wudli, As you asked, please find the hexpad example attched (an1170_13.zip). Please be aware that Cypress is no longer supporting this application note and the associated example. We are in process of upgrading our linux support. But till that time our linux support is limited. In mean-time you can use third party linux support. The details are listed in KB article (http://www.cypress.com/?id=4&rID=29746). Along with this, for linux application development, you can also use third party library libUSB ( http://www.libu***.org/). Thanks, Samir
谢谢萨米尔的快速回答。是的,也许我最终会使用LiBub。但首先我想尝试一个例子。谢谢你
以上来自于百度翻译 以下为原文 Thank you Samir for the quick answer. Yes, probably I will eventually use libu***. But first I wanted to try an example. Thank you |
你好
我也曾试过这个例子表明柏Hexpad但没有工作。我需要在Linux中运行我的USB设备。如有任何帮助,将不胜感激。 最好的问候 以上来自于百度翻译 以下为原文 hello i have also tried this hexpad example suggested by cypress but it didnt work. i need to run my u*** device in linux . any help will be highly appreciated. Best Regards |
你好
我使用这个库在Linux下进行设备编程: HTTPS://GITHUBCOM/MulcIGN/FX2LIB 图书馆有一些例子可以尝试。为我工作,但不是Python脚本。我使用Python而不是用LIUSB总线与目标进行通信 HTTP://LIUBB.SooSoCurgE.NET/API1.0/ 为了下载固件,我需要这个: www. Makestuff.Eu/WordPress 以上来自于百度翻译 以下为原文 hello I use this library for device programming under linux: https://github.com/mulicheng/fx2lib The library has examples to try. Worked for me but not the python scripts. I use python instead of c with libu*** to communicate with the target http://libu***.sourceforge.net/api-1.0/ And for download the firmware to the targed , i need this: www.makestuff.eu/wordpress/ |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:32 , Processed in 0.674901 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1400
