电子发烧友论坛|
请问C5509A的中断向量程序怎么写啊?什么思路啊?
3 个讨论
你好,
你是要中断向量表吗? 在裸机情况下, 中断程序跟普通的程序一样, 只不过前面需要interrupt关键字来定义, 然后把函数名(前面需加下划线)填写到中断向量表对应的中断位置. 下面是中断向量表的写法 * * Copyright (C) 2003 Texas Instruments Incorporated * All Rights Reserved * * *---------vectors_dma2.s55--------- * * Assembly file to set up interrupt vector table * .sect ".vectors" *------------------------------------------------------------------------------ * Global symbols defined here and exported out of this file *------------------------------------------------------------------------------ .global _VECSTART *------------------------------------------------------------------------------ * Global symbols referenced in this file but defined somewhere else. * Remember that your interrupt service routines need to be referenced here. *------------------------------------------------------------------------------ .ref _c_int00 .def nmi, int0, int1, int2, int3, int4, int5, int6 .def int7, int8, int9, int10, int11, int12, int13 .def int14, int15, int16, int17, int18, int19, int20 .def int21, int22, int23, int24, int25, int26, int27 .def int28, int29 _VECSTART: .ivec _c_int00,use_reta nmi .ivec no_isr nop_16 int0 .ivec no_isr nop_16 int1 .ivec no_isr nop_16 int2 .ivec no_isr nop_16 int3 .ivec no_isr nop_16 int4 .ivec no_isr nop_16 int5 .ivec no_isr nop_16 int6 .ivec no_isr nop_16 int7 .ivec no_isr nop_16 int8 .ivec no_isr nop_16 int9 .ivec no_isr nop_16 int10 .ivec no_isr nop_16 int11 .ivec no_isr nop_16 int12 .ivec no_isr nop_16 int13 .ivec no_isr nop_16 int14 .ivec no_isr nop_16 int15 .ivec no_isr nop_16 int16 .ivec no_isr nop_16 int17 .ivec no_isr nop_16 int18 .ivec no_isr nop_16 int19 .ivec no_isr nop_16 int20 .ivec no_isr nop_16 int21 .ivec no_isr nop_16 int22 .ivec no_isr nop_16 int23 .ivec no_isr nop_16 int24 .ivec no_isr nop_16 int25 .ivec no_isr nop_16 int26 .ivec no_isr nop_16 int27 .ivec no_isr nop_16 int28 .ivec no_isr nop_16 int29 .ivec no_isr nop_16 *------------------------------------------------------------------------------ * This is a dummy interrupt service routine used to initialize the IST. *------------------------------------------------------------------------------ .text .def no_isr no_isr: b #no_isr *------------------------------------------------------------------------------ |
60user131 发表于 2019-1-28 09:16 c55x有32个中断源, 每个中断向量只能放8个byte, 而通常中断向量子程序会超过8byte, 所以会在中断向量的第一个byte放中断子程序地址, 中断产生后, 会跳转到中断子程序执行. 没有用到的中断向量, 就做空操作. 建议你看一下下面user guide 第5.2 Interrupt Vectors and Priorities章节 http://www.ti.com/lit/ug/spru371f/spru371f.pdf nop_16是一条空操作指令, PC指针跳2个byte .ivec是一条汇编伪指令, 表示中断向量入口地址, "use_reta", .ivec具体可以看下面的汇编手册第113页. http://www.ti.com/lit/ug/spru280i/spru280i.pdf "no_isr"在最底下定义了 .text .def no_isr no_isr: b #no_isr |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:54 , Processed in 0.527896 second(s), Total 41, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3072
