电子发烧友论坛|
NVSRAM有一个机制来计算“存储”启用的次数吗?如果没有,有什么方法来计算这个?谢谢,弗兰克
以上来自于百度翻译 以下为原文 Does the NVSRAM have a mechanism to count the number of times the "STORE" is enabled? If not, is there any way to count this? Thanks, Frank |
1个回答
嗨,弗兰克,NVSRAM没有任何功能来计算存储的次数。商店可以以三种方式发起:1。自动存储(当电源关闭时自动存储)-当系统VCC低于Vwitter(名义上为5V部分的4.2V)时,整个SRAM阵列将被安全地存储在EEPROM中,最大值为10毫秒,此时NVSRAM不可用。这个操作在NVSRAM被称为AutoSt店。2。软件商店(用户触发)-在软件商店操作的情况下,存储操作是通过依次读取六个地址的特定序列来启动的,没有对其他位置3的中间访问。硬件存储(用户触发)-如果在读取或写入期间断言NVSRAM中的HSB(硬件存储繁忙)PIN,则将分别启动存储操作。这被称为硬件存储操作。此外,为了节省存储周期,如果在先前的召回操作之后没有发生写入,则不触发硬件存储和AutoStore。因此,为了计数存储到非易失性存储器的数目,可以计算上述三个条件中的任何一个的发生。问候,Pavan
以上来自于百度翻译 以下为原文 Hi Frank, The NVSRAM does not have any function for counting the number of times STORE is done. The STORE can be initiated in three ways: 1. AutoStore (Automatic Store when power goes off) - When system Vcc drops below VSWITCH (nominally 4.2V for 5V parts) the entire SRAM array will be stored safely into EEPROM in a maximum of 10 milliseconds, and the NVSRAM is unavailable to the system at this time. This operation is called an AutoStore in NVSRAM. 2. Software STORE (User triggered) - In case of Software STORE operation, STORE operation is initiated by Reading a specific sequence of six addresses in order, with no intervening access to other locations 3. Hardware STORE (User triggered) - If the HSB# (Hardware Store Busy) pin in NVSRAM is asserted during either Read or Write, a STORE operation will be initiated respectively. This is called a Hardware STORE operation. Further, to save the number of STORE cycles, Hardware STORE and AutoStore are not triggered if no write has happened after previous RECALL operation. Therefore, in order to count the number of STORES to non-volatile memory, the occurrence of any of the above mentioned three conditions may be counted. Regards, Pavan |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7404 浏览 0 评论
2491 浏览 1 评论
2183 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2093 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7882浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6450浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
735浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8300浏览 2评论
/9
GMT+8, 2025-12-15 09:50 , Processed in 0.613530 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6534
