我需要使用STM32f030 的tiM1 的CH2和CH3通道输出互补PWM信号,实际测试发现PB14(TIM1_CH2N)PB15(TIM1_CH3N)无法输出,而TIM1_CH2和TIM1_CH3能正常输出。一直找不到原因。TIM1初始化程序如下:
void Time1_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; //TIM_PeriodÉèÖÃÁËÔÚÏÂÒ»¸ö¸üÐÂʼþ×°Èë»î¶¯µÄ×Ô¶¯ÖØ×°ÔؼĴæÆ÷ÖÜÆÚµÄÖµ¡£ËüµÄȡֵ±ØÐëÔÚ0x0000ºÍ0xFFFFÖ®¼ä TIM_TimeBaseStructure.TIM_Period = TimerPeriod; //ÉèÖö¨Ê±Æ÷Ô¤·ÖƵֵΪ0 //TIM_PrescalerÉèÖÃÁËÓÃÀ´×÷ΪTIMxʱÖÓÆµÂʳýÊýµÄÔ¤·ÖƵֵ¡£ËüµÄȡֵ±ØÐëÔÚ0x0000ºÍ0xFFFFÖ®¼ä TIM_TimeBaseStructure.TIM_Prescaler = 0; //ÉèÖö¨Ê±Æ÷ʱÖÓ·ÖÆµÖµ TIM_TimeBaseStructure.TIM_ClockDivision = 0; //ʱÖÓ·Ö¸î TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //ÉèÖö¨Ê±Æ÷ÏòÉϼÆÊý TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //ÉèÖö¨Ê±Æ÷ÖØ×°ÔØÖµ TIM_TimeBaseInit(TIM1, & TIM_TimeBaseStructure); //ÅäÖö¨Ê±Æ÷1 /* ƵµÀ1£¬2£¬3£¬4µÄPWM ģʽÉèÖà */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //PWM1ģʽ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //Êä³ö±È½Ï״̬ TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //»¥²¹Êä³ö±È½Ï״̬ TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //Êä³ö¼«ÐÔΪL TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; //»¥²¹Êä³ö¼«ÐÔΪH TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; //¿ÕÏÐ״̬ÏÂÊä³ö¼«ÐÔReset TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; //¿ÕÏÐ״̬»¥²¹ÏÂÊä³ö¼«ÐÔ TIM_OCInitStructure.TIM_Pulse = Channel2Pulse; //ʹÄÜÆµµÀ2ÅäÖÃÖÜÆÚ TIM_OC2Init(TIM1, &TIM_OCInitStructure); TIM_OCInitStructure.TIM_Pulse = Channel3Pulse; //ʹÄÜÆµµÀ3ÅäÖÃÖÜÆÚ TIM_OC3Init(TIM1, &TIM_OCInitStructure); //TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable); //ʹÄÜͨµÀ2Ô¤×°ÔØ //TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable); //ʹÄÜͨµÀ3Ô¤×°ÔØ //TIM_ARRPreloadConfig(TIM1, ENABLE); /* PWM ËÀÇøÊ±¼äÉèÖà */ TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; //Enable Running State TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable; //Enable Idle State TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1; //Set the lock level TIM_BDTRInitStructure.TIM_DeadTime = 20; //ËÀÇøÊ±¼ä:0x00-0xff TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable; //Enable the Break function TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High; TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable; //ʹÄÜ×Ô¶¯Êä³ö. TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure); TIM_ClearFlag(TIM1, TIM_FLAG_Update); //Çå³ýÖжϱêÖ¾·ÀÖ¹ÅäÖÃÍê³É´ò¿ªÖжÏʱÁ¢¼´²úÉúÖÐ¶Ï //TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE ); //ʹÄܶ¨Ê±Æ÷1¸üÐÂÖÐ¶Ï TIM_Cmd(TIM1, ENABLE); //ʹÄܶ¨Ê±Æ÷1¹¦ÄÜ TIM_CtrlPWMOutputs(TIM1, ENABLE); //TIM1 Ö÷Êä³öʹÄÜ } IO初始化 RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE); GPIO_InitStruct.GPIO_Pin = TxD2 | RxD2 | PWM1L | PWM2L; //¶Ë¿ÚTxD2 -> PA2 / RxD2 -> PA3 / PWM1L -> PA9 / PWM2L -> PA10 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; //¸´Óà GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; //×î´óÊä³öËÙ¶È50MHz GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; //¸´Óù¦ÄÜÍÆÍìÊä³ö GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP ; //ÉÏÀ GPIO_Init(GPIOA, &GPIO_InitStruct); GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1); //USART2_TX GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1); //USART2_RX GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2); //TIM1_CH2 GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2); //TIM1_CH3 RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE); GPIO_InitStruct.GPIO_Pin = TxD1 | RxD1 | PWM1H | PWM2H; //¶Ë¿ÚTxD1 -> PB6 / RxD1 -> PB7 / PWM1H -> PB14 / PWM2H -> PB15 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; //¸´Óà GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; //×î´óÊä³öËÙ¶È50MHz GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; //¸´Óù¦ÄÜÍÆÍìÊä³ö GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP ; // GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_0); //USART1_TX -> PB6 GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_0); //USART1_RX -> PB7 GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_2); //TIM1_CH2N GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_2); //TIM1_CH3N 找了很久找不到问题点。 |
5个回答
你好,请问是什么原因?最后怎么解决的呢?我现在也是遇到这个问题怎么搞都没有输出。。。。。。
寄存器,古老的是好东西。被很多人忘了...
好久了,我也不记得改哪里了,要仔细核对一下寄存器。 |
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2); //TIM1_CH3 GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_2); //TIM1_CH2N GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_2); //TIM1_CH3N 这里TIM1_CH2和TIM1_CH2N的引脚复用GPIO_AF_2的AF_后面的数字不能一样,其中一个改成GPIO_AF_0就可以了 同理可得将TIM1_CH3和TIM1_CH3N的引脚复用GPIO_AF_2也修改为GPIO_AF_0和GPIO_AF_2就可以了 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-1 20:27 , Processed in 0.860351 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3502
