电子发烧友论坛|
您好,我有一个PHASELOCK LOST错误。
我让机器在水中死机并修复了电源; 我不确定错误是否相关。 似乎存在所有电源电压(除了9VDC的状态未经测试...没有原理图或电源扩展板可用)。 UUT从大约11 MHz到205 MHz都可以。 其他一切都是噪音。 我在2 GHz处的端口1处有大约0 dBm的电源输出,根据文档,这表明信号源正常,问题出在A11 Phaselock板上。 我做了一个操作系统恢复,问题仍然存在。 接收机测试显示A,B,R1和R2均匀下降约70 dB。 我的固件是A.07.50.67; 我曾尝试过早期的固件。 有一件事很奇怪:在6ms扫描速率下,UUT扫描然后在开始新扫描之前挂起6秒(CPU似乎在延迟期间挂断)。 更改BW或点数不会影响扫描速率。 此外,串行总线测试在每次测试中挂起约60秒。 机器上的串行总线测试与文档SB测试不同。 对此的任何想法也将受到赞赏。 感谢任何见解,Rick 以上来自于谷歌翻译 以下为原文 Hello, I have a PHASELOCK LOST error. I got the machine dead in the water and repaired the power supply; I am not sure if the error is related. All supply voltages seem to be present (except the status of the 9VDC is untested...no schematics or Power Supply extender board available). The UUT is OK from about 11 MHz to 205 MHz; everything else is noise. I have about 0 dBm power out at port 1 at 2 GHz which, according to the documentation, indicates that the source is OK and that the problem is in the A11 Phaselock board. I did a Operating System Recovery, problem still there. The receiver test shows A, B, R1, and R2 uniformly down about 70 dB. My firmware is A.07.50.67; I have tried earlier firmwares. One thing that is strange: with a 6ms sweep rate, the UUT sweeps then hangs up for 6 seconds before starting a new sweep (the CPU seems to hang up during the delay). The sweep rate is not affected by changing the BW or number of points. Also, the serial bus test hangs up about 60 seconds into each test. The serial bus test on the machine doesn't resemble the documentation SB test. Any thoughts on that would be appreciated as well. Thanks in advance for any insights, Rick |
2个回答
瑞克,你很可能有一个坏的压裂N卡组件和可能的输出卡组件。
电源故障通常会导致其他电路板因其死亡方式而开始变坏时发生故障。 我们在本系列和E880x分析仪中多次看到这个问题,因为它们使用相同的电源。 该装置需要维修并完全重新调整和测试。 您可以联系罗斯维尔的Dan Allen,了解该单位的服务。 dan_allen@agilent.com。 提到我把你推荐给他,他可以处理一切。 以上来自于谷歌翻译 以下为原文 Rick, You most likely have a bad frac N card assembly and possibly an output card assembly. The power supply failure has generally caused other boards to fail when it starts to go bad due to the way it dies. We have seen this problem many times in this series and the E880x analyzers as they use the same power supply. The unit will require repair and to be fully realigned and tested. You can contact Dan Allen in Roseville about service of this unit. dan_allen@agilent.com. Mention I referred you to him and he can handle everything. |
小佳99 发表于 2019-1-16 18:42 感谢您的回复。 我们已经将该设备送到安捷伦进行评估(不幸的是,它在运输过程中损坏了,所以我们正在对其进行分类):o) 以上来自于谷歌翻译 以下为原文 Thanks for your reply. We have sent the unit into Agilent for evaluation (unfortunately, it got damaged in shipping, so we are sorting that out) :o) |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 05:46 , Processed in 0.635694 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2365
